Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
OMG I love this concept! Sooo appropriate!
You did a great job fitting the ruined cottage into your background.
@IceDragonArt
Thank you. The cottage isn't perfect and the DOF doesn't quite tie it into the background but it worked better than I thought it would.
I've been away for a while and this is my latest render since returning.
Northern Lights
2017-12-17 16:12:32.562 Total Rendering Time: 3 hours 54 minutes 53.31 seconds
WorldBase XT - Snowlands Pak
American Bison Catalyzer
DigiVault Stardomes - Aurora Borealis
Click on image for full size.
Daylight
2017-12-17 22:15:10.271 Total Rendering Time: 1 hours 15 minutes 47.56 seconds
This animation just grew from a post about HDRIs :)
Happy Snowman
Trying out some new purchases.
2017-12-22 20:38:41.795 Total Rendering Time: 4 hours 44 minutes 1.93 seconds
Epic Props: Godrays & Volumetric Light for Iray (https://www.daz3d.com/epic-props-godrays-volumetric-light-for-iray)
Iray Machina Materials for Genesis 3 Female (https://www.daz3d.com/iray-machina-materials-for-genesis-3-female)
I rendered the scene again with just the HDRI, all other lights are off, and set it back to defaults.
2017-12-23 11:50:56.453 Total Rendering Time: 50 minutes 10.39 seconds
Just some experiments using lights and volumes.
2017-12-26 20:24:34.040 Total Rendering Time: 6 hours 18 minutes 29.26 seconds
2017-12-26 21:39:42.787 Total Rendering Time: 32 minutes 23.0 seconds
2017-12-26 22:49:04.278 Total Rendering Time: 55 minutes 5.42 seconds
2017-12-27 17:33:43.333 Total Rendering Time: 2 hours 48 minutes 11.42 seconds
Dark Attic Room and M4 Skeleton. Light is the candle flame made Emissive.
The Last Reading.
2017-12-28 20:49:22.458 Total Rendering Time: 5 hours 34 minutes 41.15 seconds
I really like the night winter scene and I love The Last Reading.
Thank you for looking and the nice comments.
The Wolf at the Door
2018-01-06 18:53:46.164 Total Rendering Time: 2 hours 34 minutes 49.72 seconds
2018-01-07 11:29:19.054 Total Rendering Time: 2 hours 43 minutes 43.7 seconds
On a world far away.
Planet Gilse
2018-01-08 23:52:25.981 Total Rendering Time: 2 hours 45 minutes 27.70 seconds
Spaceport
2018-01-13 23:45:30.966 Total Rendering Time: 1 hours 34 minutes 27.3 seconds
Love your latest renders, esp the sci fi. Are the neat colorful renders (such as the swan and snow) done with something like tonal rage? Or are you using individual colored lights? Either way, awesome effects.
@Worlds_Edge
The snow only has the HDRI and a Distant Light but I changed the refraction index and weight for the snow which gives it the blueish tinge. The Swan image is as it comes except the HDRI is one I made in Bryce, the swan I made Emissive and I increased the lumens on the Emissive lights which are those gold 'flowers'.
Love the reflections on the water in the Planet Glise render and the point of view on the sci fi render. My question is, is the wolf at the door friendly? or is he going to sneak in and wreak havoc lol.
@IceDragonArt
He's just hungry and looking for scraps.
Well then, hopefully he will find some (I have a huge fondness for wolves lol)
@Fishtales
Some really nice renders! Is the SF rendered in 3DL or Iray? That's a stardome from Digivault, right? Or did you convert it somehow?
Love the wolf too:)
@Sven Dullah
All renders are Iray. I load the stardome, use the HDRI in the Environment Dome and then delete the stardome from the scene.
Beast Slayer
2018-01-20 20:51:57.124 Total Rendering Time: 14 minutes 0.47 seconds
I redid the last render. I had used an emissive plane at the side to fill in the light on the front of the figures. I didn't like the result so deleted it and used the Exif settings for the background image and entered them into the camera and Tone Mapping settings which worked much better.
2018-01-21 09:26:12.086 Total Rendering Time: 18 minutes 3.5 seconds
The second one is definitely an improvement. Is it weird that I always feel sorry for the beasties?
Well. That's a simple and elegant solution.
@IceDragonArt
I do that a lot with Skydomes :)
I didn't realize it could be that simple. I have a ton of skydomes that are basically useless because the other conversion process just takes too long.
@IceDragonArt
Not all the images used in a Skydome will work but it is always worth trying :)
This is Terradome3, Genesis 3, Aftermath Parched, ATV 4x4, Crows from Flock of Gulls, one distant light where the sun is and the .jpg from Merlins Crossing skydome in the Environment Map of the Iray Dome.
2018-01-25 18:42:20.521 Total Rendering Time: 1 hours 14 minutes 12.41 seconds
2018-01-25 20:53:29.005 Total Rendering Time: 1 hours 17 minutes 38.50 seconds
2018-01-25 22:27:53.854 Total Rendering Time: 1 hours 14 minutes 35.76 seconds
2018-01-26 09:13:42.146 Total Rendering Time: 54 minutes 49.9 seconds
2018-01-26 12:34:24.004 Total Rendering Time: 1 hours 14 minutes 42.37 seconds
This one uses my own image as a Background, Noggin's Crow and Squirrels by AM. I also used four Matte objects to try and get them to look as if they are in the image and not sitting in top :)
2018-01-26 18:09:44.941 Total Rendering Time: 41 minutes 3.94 seconds
Mil Horse Unicorn, HDRI and a Distant Light for lighting and background and a tree for the dappled shade.
2018-01-29 17:44:46.242 Total Rendering Time: 36 minutes 26.24 seconds
