PC specs
Hi All
Running Win10 kept updated installed on a 256GB SSD, 16GB corsair ram, AMD 8320 8 core CPU and GTX1060 graphics card.
How should DAZ perform whilst just working in DAZ ? WIth a single character it is fairly fast to navigate and load the character. But if i have more than two it slows down and i battle to navigate. Also the scene takes forever to load.
I use the Texture Shaded option when i want to get a fairly clear view of what my scene / char will look like but navigating i change it to wireframe which is fast. Still Texture Shaded it's just dead slow.
Blender, Photoshop runs fine.
Reinstall my DAZ or upgrade my ram some more? I do however have a lot of stuff added on in my DAZ.
  • plarffplarff Posts: 287
    edited January 2018
    Seems im not the only one with this problem... lots of viewers no suggestions to speed things up. Probably the answer is either a 6GB memory card or SLI configuration.
    I have also seen a script command that clears memory cache can anyone confirm if this helps?
    Post edited by plarff on
  • Iray does not use SLI, and in fact nVidia advises disabling it (in the driver) for Iray applications as far as I know). As for the preview, that's purely OpenGL but there are speed-ups available - go to Edit>Prefrences>Interface tab and make sure that Display Optimisation is set to Best (which should be safe on your system).
    Thank you will give it a try
  • plarff said:
    Hi All
    Here's an article that might help you out.
    http://www.logicalincrements.com/articles/building-pc-3d-rendering-animation
    plarff said:
    Hi All
    Thank you, reading it now.
