Modeling Objects in Carrara - Q&A - Come One and All
1454648505153
  • Would love to know what parts of the world you all are from?
    I'm in Florida here. Almost all the way down at the bottom.
    Thanks for the help! It’s about 10 degrees outside here in the lou so if you get overheated and want to trade spots I’m game haha jkjk
    I moved here from upstate New York. I'm in no hurry to experience winter at those temperatures again. lol
  • PhilWPhilW Posts: 5,162
    Tina, in case you weren't aware of it, please be sure to look at the thread dedicated to his memory, there are lots of messages and images there already. I hope that it is comforting to know that he made many friends here from all around the world and made a difference. He will be much missed.
    https://www.daz3d.com/forums/discussion/224721/sad-news-passing-of-wgdjohn
  • StezzaStezza Posts: 8,831
    wgdjohn said:
    Crazy John's current toy... A Walker - with added a brace:  I've still got one more brace below this one, about 6+ inches, to add which is designed different... the next brace bends somewhat like the top but gets flattened against the large frame... hangs down.  Note that one leg of frame is shorter for the currently nonexistent wheel.  Oh... the brace shown is supposed to have a slight bend at center... the one I've not done yet is straight across with bends only where it mounts to main frame.
    [update - Oct. 8, 2:15am]  I just couldn't leave it alone so went ahead and added the 2nd brace.  Now have the adjustable height tubes for front and rear of main frame...  can't wait to start the wheel which should be interesting.  So far have 4 polymeshes in one vertex object... the handle, main frame and 2 diff support bars.
    I thought I'd finish a walker for John..
  • HeadwaxHeadwax Posts: 10,441
    wow Stezza, I think he'd be stoked
    How awesome! He would’ve loved that...wherever he is now I’m sure he is smiling down
  • DiomedeDiomede Posts: 15,398
    edited February 2018
    Formula Torus with Parameters
    This modification of a preset on "that great French formula site" is a torus.  You can use p1 and p2 to make the torus thicker/thinner and larger/smaller.
    Insert a formula object to your scene.
    Copy and paste the following formula to the properties tray box.  Click parse.  Save to your browser.  Adjust p1 and p2 to taste.
    d=1+p1;e=1+p2;
    p=2*PI*(u-0.5);
    q=2*PI*(v-0.5);
    x=(d+e*cos(q))*cos(p);
    y=(d+e*cos(q))*sin(p);
    z=e*sin(q);
    See pic for the p1 and p2 settings for that shaped torus.
    1742 x 945 - 174K
    Post edited by Diomede on
    Here is the torus with those p1 and p2 settings converted to a vertex object at 100% fidelity an then untriangulated.
    1868 x 952 - 261K
    Same formula but with different p1 and p2 settings, and a lower fidelity when converting to a vertex model.
    1502 x 867 - 109K
    Formula Model - Not UV Mapped -
    Applying Procedural Shaders
    Place Logo
    640 x 480 - 25K
    640 x 480 - 25K
    how would you fill an oval with quads?
    trying to avoid tris
    did fill
    tysmiley
    Post edited by Mistara on
    did fill
    tysmiley
    It depends on how many edges the oval has. Can you post a quick screencap of yours?
    The aim is to get something like the image below, but how you go about it depends on the number of edges/points:
    724 x 544 - 14K
    Post edited by MarkIsSleepy on
    I would usually extrude once to get an inner line to brace the circle.  That way any smoothing would tend to be more consistent.  The inner area can be larger polygons.
    Here are some examples for 12, 20 and 24 pointed ovals.  Carrara's default oval is 20 points.
    1735 x 975 - 118K
    1521 x 968 - 99K
    1521 x 968 - 99K
    i'm doing the the eyedrop bottle.  the bottom of bottle is ngon.
    imo,, a clean model is all quads.
    that first 1 you posted looks neatly smiley
    gordon, lathing, lofting,  ixnay acute tris  lol
  • VyusurVyusur Posts: 2,235
    I've just recorded a short video on the filling with quads etc. https://youtu.be/ENQIgt1lTh4
    Speed is left intact.
    Post edited by Vyusur on
    Elegant modelling!
    Phil, thank you very much! I've just updated the link.
    Kewl!!  smiley
    Wonderful videos, Veronika.  Noticed a couple new ones, or maybe just ones I hadn't seen.  Thank you.
  • IceDragonArtIceDragonArt Posts: 12,899
    Thank you so much for making this a sticky thread.
    edited April 2018
    Toon animal
    Working on a toon saber tooth tiger
    - started by creating simple shapes for the body and head
    - threw in some legs
    - of course some details for the head
    - welded the major parts
    1883 x 887 - 138K
    1863 x 957 - 156K
    1495 x 966 - 129K
    1897 x 917 - 180K
    edited April 2018
    - attach head and extrude in for the mouth
    - Worked on details like claws and face
    1784 x 1033 - 195K
    1852 x 1012 - 180K
    edited April 2018
    Haven't uvmapped it or rigged it yet, but here are some test renders
    - again, intent is a toon saber tooth tiger
    1600 x 1200 - 95K
    1600 x 1200 - 74K
  • DesertDudeDesertDude Posts: 1,239
    Fantastic work, as usual Diomede. Thanks for sharing!
    Intent achieved I would say!
    Thanks, guys.
    This cat may feature prominently in an animation I am working on - as per Phil's animation tutorials.
    I hope you've got a nice walk cycle for it then!
    edited April 2018
    crouch and pounce!
    saber tooth tigers don't waste energy merely walking.  wink
    Really wanted to enter it in the time travel challenge when Stezza said animations were eligible.
    EDIT:  The tiger is not even rigged yet.
    Diomede said:
    crouch and pounce!
    laugh
