Trying to fit Top Model Updo to G8...styling presets don't work. Any ideas how to fix?
Thank you!
  • Don't "fit" it. Edit the scene identification.
  • nicsttnicstt Posts: 11,714
    edited January 2018
    Load the hair, select it (if not already) once its loaded.
    See image
    Works best with G3 to G8; can work with earlier versions to G8, but are likely to be more issues, but often worth it get all the bones available.
    1396 x 738 - 101K
    Post edited by nicstt on
  • posecastposecast Posts: 386
    Ok, I think there might be something missing in your screenshot...I cant figure out which drop down to pick to get that "Genesis 8/Female" selection to show up. I'm fitting this to Pei if that helps. Thanks so much I think I am getting close!
  • WonderlandWonderland Posts: 6,742
    Or you can try manually placing it and parenting it. Then the bones should still work...
  • LlynaraLlynara Posts: 4,770
    I do this on many hairs and they work perfectly. Make sure the figure is zeroed to make it easier. You can literally put any hair on any figure this way. Just scale to fit, use translate if needed (ie super short or tall characters.)
  • FSMCDesignsFSMCDesigns Posts: 12,601
    See image
    I can never find the genesis 8 optioin in the dropdown and I know it has something to do with CMS from another thread, but can't seem to figure it out.. Anyone have an idea how to get it to show up
    See image
    Try uninstalling and reinstalling G8.
    Ok, i found where g8 is and selected female, but now when i bend the neck, the hair stays in place. Any ideas?
  • agent unawaresagent unawares Posts: 3,513
    edited January 2018
    After you change the scene identification you should be able to fit the hair to G8 and it will work normally instead of going through autofit which breaks things.
    Post edited by agent unawares on
    That worked. Thanks!
    See image
    i assume this is possible with DIM as I am not seeing an uninstall anywhere from a manual install. Guess I could try the control panel if all else fails.
    See image
    Yes you can uninstall with DIM from the Installed tab.
  • davidtriunedavidtriune Posts: 452
    edited April 2019
    you dont even need to move your character. just drag the hair into the scene, set parent to head, and reset the parameter values for translate and rotate.
    397 x 433 - 30K
    1038 x 487 - 120K
    Post edited by davidtriune on
