G8f fish lips?
Can anyone help me figure out why my g8f characters all load with terrible looking fish lips? It's like they are all doing the duck face selfie.
  • WandWWandW Posts: 2,907
    Do you have an example?
    Also, what is the focal length settign on your camera?  Low values can cause distortion...
  • It happens on every camera, so I think its something wrong with the figure. Attached some examples.
    943 x 943 - 546K
    943 x 943 - 1003K
    943 x 943 - 1M
    943 x 943 - 1M
    943 x 943 - 983K
    @bigcurf
    You have probably saved some other morph to your base model that causes the distortion.
  • Nope, have deleated and re-installed, same. I also used the model from daz connect same problem.
    In the Parameters Tab for V8, what morphs show up when you select 'Currently Used' at the top?
  • V8 , V8 body, V8 head, navel, mouth realism HD
  • Try showing hidden properties and checking it again, because it does seem like there is something affecting the figure that shouldn't be.
  • I sure cant figure it out, I guess it's unusable. What a waste.
  • CrescentCrescent Posts: 335
    What if you zero out the figure shape then try Teen Josie, for example?  Does it still look off?
  • Same thing even if I zero it out.
    When was the last time the lips looked normal? You may have to uninstall recent products and figure out which one is triggering the others. I had to do that one time with a male morph that distorted the chest.
  • The only time they look normal is on the base figure.
  • Hi! I had this problem before and found that it was the Demona character. The head was always loading in at 100%, but for some reason was not showing in the 'Currently Used' section. I suspect it is a bug in that character.
    Do you have Demona installed? If so, try checking that it is not loaded, or that the head shape is not set to 100%.
  • Ding ding, we have a winner! Thank you Blacky13, you solved the mystery.
  • Awesome! Glad I could help.
