G8f fish lips?
Can anyone help me figure out why my g8f characters all load with terrible looking fish lips? It's like they are all doing the duck face selfie.
Do you have an example?
Also, what is the focal length settign on your camera? Low values can cause distortion...
It happens on every camera, so I think its something wrong with the figure. Attached some examples.
@bigcurf
You have probably saved some other morph to your base model that causes the distortion.
Nope, have deleated and re-installed, same. I also used the model from daz connect same problem.
In the Parameters Tab for V8, what morphs show up when you select 'Currently Used' at the top?
V8 , V8 body, V8 head, navel, mouth realism HD
Try showing hidden properties and checking it again, because it does seem like there is something affecting the figure that shouldn't be.
I sure cant figure it out, I guess it's unusable. What a waste.
What if you zero out the figure shape then try Teen Josie, for example? Does it still look off?
Same thing even if I zero it out.
When was the last time the lips looked normal? You may have to uninstall recent products and figure out which one is triggering the others. I had to do that one time with a male morph that distorted the chest.
The only time they look normal is on the base figure.
Hi! I had this problem before and found that it was the Demona character. The head was always loading in at 100%, but for some reason was not showing in the 'Currently Used' section. I suspect it is a bug in that character.
Do you have Demona installed? If so, try checking that it is not loaded, or that the head shape is not set to 100%.
Ding ding, we have a winner! Thank you Blacky13, you solved the mystery.
Awesome! Glad I could help.
