Adding to Cart…
Then there's something fundamentally corrupt with your database.
Close DS.
Make sure the database service is stopped.
MOVE everything in the databases folder to a backup location.
Start the CMS service.
Wait 1 minute.
Start DAZ Studio.
After DS has started go to the Content Library tab.
Click the context menu at the top, select "Content DB Maintenance"
Make sure the "Re-import Metadata" check box is checked.
Click Accept.
Wait until complete.
Check categories under Default and make sure it's populated.
Just in case, did you check the log file of the cms in the vlogs folder? Does it contains an error message?
Did all that its not populated. Also CMS has stopped in services
where is vlogs folder
Also do i need to delete everythin in databse folder?
Categories default is populated now. But my old categories aint there
Yes, the databases folder needs to be empty before you restart the service. That's why I said move not copy. :)
how do i get my old categories
Your database was irrevocably corrupt.
