How to get the Optitex Burque Victoria 4 to fit to Genesis 8 Female?
nonesuch00
Hey,
OK so I downloaded the item Burqua Victoria 4 from:
http://www.optitex-dynamiccloth.com/FreebieDownload14.php
and I want to make the dress fit, not the actual burqua, & drape via dForce. The trouble is when I set the dress to be a dynamic object at level 2 for simulation the dress is in a T-pose at the start of the simulation but Genesis 8 Female goes to an A-pose and so the fitting and draping never fit properly to drape properly.
How do I change this to work. I do have the full version of the optitex plugin available if that will help but it only ever frustrated me trying to use it.
Thanks.
Post edited by nonesuch00 on
Is there a problem changing the dress to an A-pose? Or G8 to a T-pose?
If you have the dress fitted on G8 in a T Pose with G8 selected you can just go to :
Edit - Figure - Memorize - Memorize Figure Pose
The animation should then start from your pose instead of the A pose
Cool thanks!
I will try this method too. Thanks.
