How to get the Optitex Burque Victoria 4 to fit to Genesis 8 Female?
nonesuch00nonesuch00 Posts: 18,874
Hey,
OK so I downloaded the item Burqua Victoria 4 from:
http://www.optitex-dynamiccloth.com/FreebieDownload14.php
and I want to make the dress fit, not the actual burqua, & drape via dForce. The trouble is when I set the dress to be a dynamic object at level 2 for simulation the dress is in a T-pose at the start of the simulation but Genesis 8 Female goes to an A-pose and so the fitting and draping never fit properly to drape properly.
How do I change this to work. I do have the full version of the optitex plugin available if that will help but it only ever frustrated me trying to use it.
Thanks.
Post edited by nonesuch00 on
  • Is there a problem changing the dress to an A-pose? Or G8 to a T-pose?
  • If you have the dress fitted on G8 in a T Pose with G8 selected you can just go to :
    Edit - Figure - Memorize - Memorize Figure Pose
    The animation should then start from your pose instead of the A pose
    Cool thanks!
    edited December 2017
    I will try this method too. Thanks.
