November issues...
EddyMI3DEddyMI3D Posts: 365
edited April 2013 in Carrara Discussion
Hello,
I just purchased the November Bundle
All works fine except the Mini skirt this is absolutely distorted. See image.
When I have a look at it in the Model Room, it looks ok.
In Studio it works fine.
Any suggestions?
Thanks in advance.
Eddy
Post edited by EddyMI3D on
  • DartanbeckDartanbeck Posts: 22,162
    Perhaps your Vicky is using an unsupported morph? That's usually the case if it looks good in the model room.
    Try fitting it to nothing, and then back to Vicky again. Or are you auto-fitting to Genesis?
  • EddyMI3DEddyMI3D Posts: 365
    When I load it into an empty scene, it isn't visible at all, only in the Model Room
    You're kidding. How strange.
    Try Edit > Send to Origin, while it is selected. Perhaps a file is missing? Maybe you need to clear your internet cache, or whatever... and download/install it again?
    edited April 2013
    I installed it with DIM. When I noticed this issue, I downloaded as EXE-Installer and put the files on the directories they belong to.
    Now I've restarted Carrara P 8.5 and loaded the skirt into an empty scene.
    It does not show up in the Assembly room.
    In Modeling Room it looks ok in Modeling Mode but disappears in Animation Mode
    In UV Editing Mode it is ok again.
    In the Texture Room there is nothing there of it too.
    Importing the obj file is also ok
    This all looks very strange
    Edit: With Edit -> Send to Origin nothing happens
    Now I've loaded the skirt into Studio and exported it as cr2 -> same result as the original one...
    Does it happen in the production build of Carrara and not the beta?
    edited April 2013
    I just reinstalled my PC. I will give it a try to C7 or C8 - after installing them
    Edit: The same issue with C7P
    So - i've connected the Help Center
    Thanks for all your suggestions.
    Eddy
