[Solved] Blurry Iray HDR
Noah LGPNoah LGP Posts: 2,617
Hi,
I don't understand why it's blurry compared to the product screenshots.
https://www.daz3d.com/daz-studio-iray-hdr-outdoor-environments
Can you tell me how to get this quality please ?
Post edited by Noah LGP on
  • Have you tried increasing it's resolution? I believe default is 512. Try using a value equal to it's width.
  • While I'm waiting for DS to load, what are your render settings and camera settings? My initial suspicion would be that you have Depth of Field on in the camera - the HDRI gives near ground and background. but it isn't really at those distances.
  • Heer are two renders, one with Depth of Field off and one with it on - the control is in the Camera group in the Paramerters pane, or in the Camera pane
    1000 x 1000 - 700K
    1000 x 1000 - 411K
  • Noah LGPNoah LGP Posts: 2,617
    edited October 2017
    It's the default Perspective View, if I copy it as a camera, Depth of Field is off
    Environment Lighting Resolution is 2048
  • FishtalesFishtales Posts: 6,231
    Try setting the Environment Lighting Resolution to 8000 and the Dome Radius to 4000 and that in Advanced/Texture Compression it is set higher than the HDRI size, which in your case is 8192, and see if that makes a difference.
    edited October 2017
    I found my mistake, the Render Mode was set to "Interactive" instead of "Photoreal".
    Thank you!! I had the same issue.
