Render Path
My renders are no longer presenting me with the option to choose a path to deposit the render to.  (No render window appears, the render process just starts.)
And I cannot locate a path selection in render settings.
How do I change the path and (if I wish to) set the render viewport to appear again, when renders are made?
  • fastbike1fastbike1 Posts: 4,085
    Click the Editor Tab
  • dash2128dash2128 Posts: 736
    Is there any reason that I am not being offered the option to select a path?
    Once, yesterday, a path option pop-up appeared, but it never reappeared.
    So, I've been rendering to one file name, copying and pasting the render somewhere else, then rendering over the last render, using the same path.
    I used to be able to choose a path.   That, was easier.
    I changed my workspace layout, and noticed why I wasn't locating the target path on the editor.
    That solved the issue.
    388 x 803 - 53K
