HDRI dome size - SOLVED
HeraHera Posts: 1,962
edited September 2017 in The Commons
I'm working on a pic with a HDR1 dome in, and when I render with the dome on, the dome gets too large, so I'm only seeing an orange, grainty blotch which is a miniscule part of the dome. I want the dome to become smaller to actually show something in the sky (heaven / clouds). How do I do that?
Post edited by Hera on
    Switch to Finite Dome, then it becomes scalable.
  • HeraHera Posts: 1,962
    Thanks a lot - MJC1016 - it worked great!
  • hansolocambohansolocambo Posts: 649
    It works except for some reason the colors change. A green and blue hdri (trees/sky), when using a finite dome, suddenly becomes yellow in some areas, pink, blue, etc. in others. It's the same image, but its look and colors are not usable anymore. Weird.
  • FishtalesFishtales Posts: 6,224
    That is because you have Show Finite Dome ticked. Remove the tick and it will go away.
