HDRI dome size - SOLVED
Hera
I'm working on a pic with a HDR1 dome in, and when I render with the dome on, the dome gets too large, so I'm only seeing an orange, grainty blotch which is a miniscule part of the dome. I want the dome to become smaller to actually show something in the sky (heaven / clouds). How do I do that?
Post edited by Hera on
Switch to Finite Dome, then it becomes scalable.
Thanks a lot - MJC1016 - it worked great!
It works except for some reason the colors change. A green and blue hdri (trees/sky), when using a finite dome, suddenly becomes yellow in some areas, pink, blue, etc. in others. It's the same image, but its look and colors are not usable anymore. Weird.
That is because you have Show Finite Dome ticked. Remove the tick and it will go away.
