Autofit and previous Gen 3 and 4 Conversions
2»
  • PendraiaPendraia Posts: 3,609
    edited March 2013
    Since the release of DIM I have been reinstalling all my content. I've now gotten to the stage where I'm starting to convert previous generations clothing to Genesis. I've also bought SickleYields great new product to assist with autofitting. So here I go...
    I started with the 50's dress from Bobbie for K4
    Process used:
    Autofit using SY's Dress
    Sent to Hexagon as I was still getting some mesh distortion(I haven't read up on SY's product so that would probably be user error. Also I'm very fussy about mesh distortion.)
    Smoothed the polys using the smoothing tool in the UV and Paint bar in Hexagon.
    Sent it back as a morph to the original dress.
    I also added a smoothing modifier prior to saving.
    Settings: Set smoothing to Generic
    Set weight to .75
    Collision iterations were left at 3
    Dress is shown on Julie shape
    Basic child
    BabyAT
    Aven
    600 x 1000 - 135K
    600 x 1000 - 182K
    600 x 1000 - 192K
    600 x 1000 - 285K
    600 x 1000 - 251K
    Post edited by Pendraia on
    Next cab off the rank All That Jazz for V4
    Most of it autofitted with no issues apart from the jewellery but I've found if I just use the jewellery as a prop figure that it's easy enough to adjust it to work and you get less distortions on the mesh.
    Shoes were the only item I added smoothing too.
    I used the SY V4 Boot to autofit
    Settings are:
    Smoothing type: Generic
    Smoothing Iterations: 21
    Collision Iterations: 8
    Changing the weight to .75 also shows a slight improvement but these images were at .50
    Aven
    V5
    Mavka
    Nata
    Satsuki
    600 x 1000 - 132K
    600 x 1000 - 120K
    600 x 1000 - 113K
    600 x 1000 - 128K
    600 x 1000 - 139K
    edited March 2013
    Now for Alice Wonderland for A3
    Alice Bloomers
    Smoothing Type: Generic
    Smoothing Iterations: 28
    Weight: .6
    Collision Iterations: 14
    Collision Smoothing Intervals: 2
    SYBodysuit
    Julie
    Aven
    A5
    ChibiGirl
    V5
    600 x 1000 - 97K
    600 x 1000 - 95K
    600 x 1000 - 101K
    600 x 1000 - 96K
    600 x 1000 - 93K
    edited March 2013
    Alice Wonderland Skirt was a little more work...
    I tried first with just a smoothing modifier which worked well for everything except an issue at the back of the mesh.
    Alice Skirt
    Using a smoothing Modifier and mesh fix
    Smoothing Iterations: 20
    Please note: you can get reasonable results starting about 10 but the more you increase this the less mesh distortion there will be. However I find that the improvements after 20 probably aren't worth the hit to your computer speed in this instance.
    I accidently keyed in 198 and the mesh became extremely smooth and square. You also lose some of the drape the higher you go.
    SYDress
    Back mesh distortion fixed in Hexagon and sent back as a morph.
    Initial mesh distortion
    Smoothing added and changed the smoothing type to Generic
    Back issue
    Back fixed by sending to Hexagon and smoothing.
    852 x 1074 - 492K
    747 x 1005 - 512K
    798 x 1059 - 410K
    795 x 1074 - 418K
    Previous post didn't show an image with the skirt at 20 smoothing iterations and also an image of what it looks like if you really increase the smoothing. This is not recommended as most machines would have issues at this level with a full render.
    840 x 1071 - 481K
    837 x 1071 - 401K
    Alice Wonderland Apron caused the most issues to convert. This is because the parts of the apron aren't joined and when smoothing is applied will separate.
    Alice Apron
    Autofit: SRMDressBase
    Smoothing Iterations: 1
    Collision Item: Alice Bloomers
    Problems due to parts of apron separating. Tried adding extra weight and Collision intervals but it didn't help.
    So I took it into Hexagon applied smoothing tool to mesh distortions on the skirt and the bodice. Needed to be careful not to do it to close to waistband or frill as they will move apart. Sent it back to DS. Added a smoothing modifier so I could collide it against the bloomers. I kept the Smoothing Iterations as low as possible as otherwise it will separate.
    Showing initial separation issues
    Satsuki
    Julie
    A5
    Mavka
    600 x 1000 - 189K
    600 x 1000 - 139K
    600 x 1000 - 160K
    600 x 1000 - 149K
    600 x 1000 - 169K
    edited March 2013
    Still plodding away and converting my Gen 3 and 4 clothing to genesis.
    Converted Bobbies Alice in wonderland for V4 today and took the time to do a render. It converted quite well using autofit and Sickles Dress template. Very minor distortion on the dress which quickly disappeared by changing the smoothing type to Generic, upping the weight to .75 and using a small amount of smoothing (5 for the dress and 6 for the shoes and socks)
    Hair is Aryelle autofitted using V4 with the long hair template no smoothing added. Some morphs used including messy and wind.
    Character .4 of Mavka and .5 of Julie with Lorella skin
    EE Road to Hell and AoA's Fog Camera
    I call it 'I want it now!'
    600 x 1000 - 223K
  • MangeyDesignerMangeyDesigner Posts: 129
    Thanks for all the detailed info on what you do with Hex, I will have to read that in more detail and see if I can make sense of it and fix things that don't fit well when I use Autofit.
    I like what you did with the Alice in Wonderand dress for A3 and this clearly shows how Autofit has improved as I tried to use that outfit for a project ages ago now and it was a real armwrestle and I managed to get somethng that worked for the couple of renders I did but it was not a real conversion and each new pose required a lot of smoke and mirrors to get it working.
    For what they are worth here are my couple of older renders with this A3 dress on Genesis. They have been heavily postworked but that was what I was going for... also it helped hide some of my sins :)
    1413 x 1999 - 384K
    1413 x 1999 - 314K
    Thanks...I started the thread to help provide information on what works for me. Some things translate more easily than others. After reading Blondie's advanced rigging tutorial, I realise that this is because of the way the mesh has been structured.
    Autofit has definitely improved since it was first introduced. Sickles rigging system has improved it further.
    There are still things that I don't understand, for example what the secondary weight does or the lock distance.
    I love your Alice renders...great job!
  • KeryaKerya Posts: 10,943
    Why hiding your sins ... it's what make people interesting. ;-)
    The pictures are looking good!
    I was referring to my autofit sins... but I don't mind if you find me interesting :P
    Those are older renders from mid last year and seeing them both together I like the one on the left far more in regards to the lighting and the composition... but I was focussing on making a storybook Alice character and I was happy with what I achieved. :)
    The one on the left is my favourite, I like the reflection in the mirror.
