Growing Up for Genesis 8 (Commercial)
135678
  • barbultbarbult Posts: 26,333
    edited September 2017
    Here's my first try with GU for G8F.
    1600 x 2000 - 2M
    Post edited by barbult on
  • Zev0Zev0 Posts: 7,123
    Nice image:) Will host a render comp soon:)
  • RainRain Posts: 352
    Zev0 said:
    silence3D said:
    great work as always zev0, any idea if we get a g8m/g8f bundle? or are you selling them both loose first?
    if you will have them loose on the store first ill just get g8f now ^
    Male version isn't finished yet. So might be a month or so. Only then will a bundle be offered.
    I couldn't wait for the bundle, I just went ahead and bought it ;-)
  • When will the Genesis 8 Male Growing Up version be available do you think... aslo will there be a bundle to buy both? ETA?
  • LeanaLeana Posts: 12,819
    See previous answer... https://www.daz3d.com/forums/discussion/comment/2790451/#Comment_2790451
    Male Promos are done.
    1000 x 1300 - 736K
    1000 x 1300 - 660K
    2000 x 1066 - 853K
    2000 x 1066 - 929K
    1000 x 1300 - 411K
    2000 x 1066 - 1M
    2000 x 1066 - 1M
    2000 x 1066 - 1M
    1000 x 1300 - 570K
    1000 x 1300 - 589K
    1000 x 1300 - 681K
    1000 x 1300 - 647K
    1000 x 1300 - 631K
    Thanks for showing the teeth, too.
    oh that's exciting!!!!! fantastic!!!!
    Zev0 said:
    HA! Finally Solved the central bulge in tops when fitted to Growing Up. Took me long enough lol....I am in the process of making a Projection morph so tops fit flush and properly on flat chested figures. Update might not be ready for release but I'll try. If not it will be released soon after. I will also try and Update the Genesis 3 Female version of Growing Up as well. Might add this to Fit Control too if I can get it across.
    Here I used the Adult setting on one image and the Young Teen on the other. This is a G8F dialed character with G3F clothes and hair. The jewelry is AllenArt freebies from ShareCG. For the Young Teen I changed the makeup and reduced the bump and normal map settings for a softer surface appearance.
    1600 x 2000 - 2M
    1600 x 2000 - 1M
    @ barbult. That is a fantastic comparison. Thanks.
    Thanks, Zev0, I'm enjoying the product. I forgot to mention, I used the Bend Control. too, but it is hard to tell under those refitted G3F pants.
    Yes. I can see actually:) Still need to add in the latest Bend Control update. Has more refinements. There was an update recently that went live that resolved a minor issue on the V8 support morphs.
    Post edited by Zev0 on
    Very nice!  What hair is that?
    Post edited by Rain on
    That is Tra La La Hair.
    Thank you!
  • scorpioscorpio Posts: 8,533
    I was going to wait for the male but caved and got the female, first render
    742 x 1200 - 220K
    Post edited by scorpio on
    LOVE it Scorpio! She looks fantastic!
  • mcorrmcorr Posts: 1,104
    will this work with 4.9.0.3, or will the add-on not launch due to scripting problems?
    Genesis 8 itaself, as I recvall, requires a much more recent version of DS. But Growing Up is content, not scripts, so it shouldn't be any worse than the base figure.
  • TooncesToonces Posts: 919
    Just wanted to say thanks for continuing to support your G3F version! I noticed the new 'GU Clothing Support' dial, and it works great!
    Thanks so much!
    Did the G3 version get updated?
    Thanks so much!
    Genesis 8 itaself, as I recvall, requires a much more recent version of DS. But Growing Up is content, not scripts, so it shouldn't be any worse than the base figure.thanks Richard!
    Thanks Richard! About your obeservation/question: Yes and no. The dialogue box warns that you need a newer version when you load G8, but you can actually load her anyway. And she's relatively functional, except for a "dual" something feature (has to do with more realistic iray skin renders, if I remember correctly), the eyelashes which I have not been able to get to work, and (to me) less important things like being able to use some powerposing or puppeteer features. There's probably more, but I've found her useable in 4.9.0.3 with some workarounds. Looking forward to the day I can upgrade my hardware/OS to to be able to use the current version of DAZ.
    Sorry for late reply. Yes G3F and M versions were updated with the clothing helper.
    Hmmm my Growing Up G3F isn't showing an update in "Updates" in Smart content. I'll give it another couple of days as I've found that updates in Smart content seem to not show for a bit.
  • I know this is not on sale and too recent for discount but I feel like it is well worth getting.  It is in my cart waiting for me to check out.
    @jakiblue, Did you ever get a Smart Content update for the Genesis 3 Growing Up products to get the clothing helper update? I never did. I have been in a back and forth discussion with CS for days about this. It just isn't working. (The update appeared in DIM, though, so I know Zev0 submitted it.)
    CS keeps saying I might already have the files.
    I keep saying:
    I do not have a "data\cloud\1_23983\data\DAZ 3D\Genesis 3\Male\Projection Morphs" folder (Growing Up for Genesis 3 Male(s).
    I do not have a "data\cloud\1_23720\data\DAZ 3D\Genesis 3\Female\Projection Morphs" folder (Growing Up for Genesis 3 Female(s).
    Do you have these files installed?
    Cannot wait!  A teen character of mine needs this with George 8! Got George 8 but waiting for this.
    Will owners of G8F version get a discount or something on the G8M version?  Please say so and it will be released in September or October?
  • Okay if this is a merchant resource, do I need to bake the morphs before submitting to Daz?  Basically what do I need to do to before submitting to Daz?
    No baking. You use it like Daz head and body morphs, where it is required in conjunction with your morph. The term merchant resource will be removed because it confuses some people. Instead I will just have rules of how product can be used on description, if people wish to sell characters using it.
    Discount wise that would be the most logical route to go. There will be an added discount. Release date depends on how the PC sale next month is going to work and how it affects PA releases not in the sale. So I will see.
