Not all Body Morphs showing after move to new computer
alienarea
Hi all,
I already raised a ticket for it, but it's the weekend and maybe one of you has a quick idea.
I got a new computer with smaller SSD (C:\) and a bigger "normal" hard disk (D:\) . I installed DAZ on the SSD but moved the content libary to D:\. I could have copied over my previous library, but decided to install everything from scratch to get a clean version and leave out products I don't use anymore, mostly 3Delight and Genesis 2.
After the installation, the Body Morphs for Genesis 3 and Genesis 8 Female show up only partially. I get the Bodybuilder morphs, but not the Fitness morphs and Height and Body Tone. However, I Ioad a figure that has been created on my old computer with these morphs, they are loaded, and I can use them for that figure, but not a new one.
I deinstalled/reinstalled the body morphs, updated the metadate, cleared the cache, rebooted, reinstalled DAZ ... problem remains.
Does anyone have an idea? Thank you.
Which panes are you checking for the morphs?
The shaping pane on the right using darkside / self serve layout.
It's also odd that they don't show as installed products except for in DIM.
Might be worth checking that they are not showing in the Parameters pane, which is a more comprehensive listing.
I resolved it by de-installing from DIM (latest version), wiping the cache, reboot snd installing through connect.
I also discovered issues with other packages that resolved the same way. Looks like DIM 32-Bit and Windows 10 64-Bit have room for improvement.
If it was a DIM issue it would affect more people.
