Not all Body Morphs showing after move to new computer
Hi all,
I already raised a ticket for it, but it's the weekend and maybe one of you has a quick idea.
I got a new computer with smaller SSD (C:\) and a bigger "normal" hard disk (D:\) . I installed DAZ on the SSD but moved the content libary to D:\. I could have copied over my previous library, but decided to install everything from scratch to get a clean version and leave out products I don't use anymore, mostly 3Delight and Genesis 2.
After the installation, the Body Morphs for Genesis 3 and Genesis 8 Female show up only partially. I get the Bodybuilder morphs, but not the Fitness morphs and Height and Body Tone. However, I Ioad a figure that has been created on my old computer with these morphs, they are loaded, and I can use them for that figure, but not a new one.
I deinstalled/reinstalled the body morphs, updated the metadate, cleared the cache, rebooted, reinstalled DAZ ... problem remains.
Does anyone have an idea? Thank you.
  • Which panes are you checking for the morphs?
  • alienareaalienarea Posts: 547
    The shaping pane on the right using darkside / self serve layout.
    It's also odd that they don't show as installed products except for in DIM.
  • Might be worth checking that they are not showing in the Parameters pane, which is a more comprehensive listing.
    I resolved it by de-installing from DIM (latest version), wiping the cache, reboot snd installing through connect.
    I also discovered issues with other packages  that resolved the same way. Looks like DIM 32-Bit and Windows 10 64-Bit have room for improvement.
  • If it was a DIM issue it would affect more people.
