Get well soon props - Thermometer for the rest of the world?
isidornisidorn Posts: 1,601
edited August 2017 in The Commons
Today's new release, the Get Well Soon Props comes with two different thermometers, both with materials for two different temperatures - in Fahrenheit! How about some love for the rest of the world?
I'm also curious. Why does a body temperature thermometer has a scale that goes down to -20F? laugh
Post edited by isidorn on
«13
  • cherpenbeckcherpenbeck Posts: 1,417
    edited August 2017
    We all know, America first, why should they aknowledge that there's a somehow still remarkably big rest of the world? wink
    Post edited by cherpenbeck on
  • kyoto kidkyoto kid Posts: 42,137
    ....the digital thermometer can be fixed fairly easily by just changing readout area to the proper celsius temperature and saving as a separate map.  For the old school one, that would be a little tougher.
  • NathNath Posts: 2,995
    I was going to comment on that as well laugh Clearly, great minds think alike.
  • FSMCDesignsFSMCDesigns Posts: 12,851
    maybe the vendor lives in the U.S.. I know if I was creating something similar I wouldn't think to use celsius or metric since I don't use it in everyday life.
  • nicsttnicstt Posts: 11,715
    edited August 2017
    The UK uses metric, but you can still see imperial (what the US uses) quantiites on items use both; I was brought up with imperial for distance measurements, but prefer metric; base ten system makes a lot more sense to me.
    But with temperature, yeh, mainly centigrade. But growing up, warm is a pleasant 70F, but freezing was 0C. Now it's all Centigrade.
    Post edited by nicstt on
    I still use fahrenheit.   I have to convert centigrade in my head first to work out how hot it is outside.  I prefer fahrenheits,  you get more degrees for your money.   Let's see   16c  divide it by 5, multiply it by 9 add on 32,   ah, that's better, now I know how warm it is, not quite 61f so not all that warm up on this welsh mountain, but it sounds warmer than 16c
    Kelvin might be more appropriate for the Welsh mountains. cheeky 70K would be positively balmy.
  • LeatherGryphonLeatherGryphon Posts: 12,235
    edited August 2017
    It's for lawyers, bank reposession managers, and one's ex.
    It's not that bad,  We are "In the foothills of the Brecon Beacons" (to use the picturesqye location description) and at around 1200ft.
    edited August 2017
    I agree. In Farenheit, when you're looking at normal daily temperatures for example, 65F versus 75F is 10 degrees, and it's the difference between kinda cool and kinda warm.
    The equivalent Celsius is 18.33C to 23.89C, which is only 1/2 that range, or a little over 5 degrees C. All those decimals and rounding off gives me a headache.
    I mean, when someone in the UK asks the temperature, is the response "18.3 degrees C"?
    Post edited by ebergerly on
  • nobody1954nobody1954 Posts: 933
    Farenheit temperatures are actually more precise than Celcius. There are 180 degrees between freezing and boiling in Farenheit.Only 100 in Celcius. As for the -20. It gets really cold here in the winter laugh.
  • Farenheit temperatures are actually more precise than Celcius. There are 180 degrees between freezing and boiling in Farenheit.Only 100 in Celcius. As for the -20. It gets really cold here in the winter laugh.
    If you use integer F and one decimal place C then it's 180 for F to 1,000 for C. Precision is a matter of choice.
  • Peter WadePeter Wade Posts: 1,682
    I wondered if the Centigrade people use Centigrade for medical thermometers. As nobody1954 says, Farenheit degrees are more precise. People measure fever temperatures in steps of 0.1 Farenheit, do they go to 2 decimal places for Centigrade?
    I'm another one who has to convert Centigrade to real degrees to have an idea of what they mean. And when did Centigrade turn into Celsius?
  • I think Celsius turned into Centigrade technically.  The scale was proposed by a dude named Anders Celsius (the idea of 100 degrees between freezing and boiling point of water).  Shortly after it was proposed to call it the Centigrade Scale, using the latin "centi" (as in centimeters, centigrams, centipoise, etc) because it was a scale of 100.  Both names work.
    Yes, thermometers for measuring human body temp use the centigrade scale in most of the world.  If you ask someone in the US what a normal human body temp reading is, I imagine you'd get 98.6F as an answer.  If you ask the same question of someone pretty much anywhere else the answer you'd get is 37C.  In my experience most home grade body temp thermometers show degrees C to 1 decimal place (e.g. 37.2, 37.3, etc).  That's plenty of resolution to figure out if you have a fever or not.
    But why would I want to know whether I have a 38,54 degree fever, rather than a 38,52 one? Maybe they do use that amount of detail in hospitals, but here at least, in common parlance fever is expressed with one decimal place. And unless a thermometer has been properly calibrated, anything more than that is false precision I'd think.
    Afaik it has always been Celsius, but the 'centigrade' thing mostly only works in English anyway. And to me, Fahrenheit temperatures are essentially meaningless until I convert smiley.
    bailaowai said:
    ...  If you ask someone in the US what a normal human body temp reading is, I imagine you'd get 98.6F as an answer.  ...
    I always thought it was 98.4  Are Americans hotter or were we just cool over here in the 60s?
    Okay, that's another thing....
    The commas instead of periods for decimals.
    Commas are for thousands, not decimals. If you see "38,54", how do you know it's not intended to be 38,540, and someone missed a zero? You write a check for $38,54 and the bank thinks you meant $38,540.
    Dude, commas are dangerous. smiley
    Internationally, they are - and yes, posting in English I should have adjusted my decimal sign :-)
  • wsterdanwsterdan Posts: 3,231
    Well, every cheque I've ever written or seen has the amount written in words as well, so not that dangerous. wink
    -- Walt Sterdan
  • The countries that use a comma for decimals use a full-stop (or period) for thousands, or just spaces.
    edited August 2017
    I belive that the US should use Centigrade and Meters instead of Farenheit and Feet but the rest of the world should use periods (.) for decimals and commas (,) for 3-digit groupings. cheeky  Can't we all just get along? surprise
    And it's toe-MAY-toes, not toe-MAH-toes.  devil
  • Robert FreiseRobert Freise Posts: 4,634
    You forgot politicians
    I was actually going to do a render with a thermometer and a sick person so this set came in handy.
    Maclean has a thermometer in this set: https://www.daz3d.com/everyday-household-items
    It is one of the old-school kind. I'm not sure what system it uses, but you might check it out.
    I was taught 98.4 in all my medical classes as being normal with a range of plus or minus 2
    Looks like it's Celsius - standard household thermometer
  • marblemarble Posts: 7,500
    edited August 2017
    -- Walt Sterdan
    You still use cheques? I don't remember the last time I wrote or received one - several years ago probably. I was banking electronically in the UK before I emigrated and it is even slicker here in New Zealand.
    As for temperature, it took me a while to adjust from F but once I did, C made much more sense. And, no, I never hear anyone say it is 18.34 degrees. 18 would do just fine.
    Post edited by marble on
  • Peter FulfordPeter Fulford Posts: 1,325
    Given that it's August, an occasional 23 or 25 would be nice. But no, the UK spends another week below 20. With frost in Scotland. In August.
  • macleanmaclean Posts: 2,438
    Yes, my 2 thermometers are in centigrade.
    and Hail stones in Wales (in August)
  • ButchButch Posts: 800
    The easy way to remember celsius is -
    Stinking hot - over 40
    Bloody hot - 30 -40
    Nice day - 20-30
    Bloody cold - 15-20
    F******* freezing - below 15
