Realistic Renders...NOT!! 11 "Hello Rogerbee!"
14344454648
    edited March 2013
    Bobvan said:
    Ever since I bought the forest set I have been determined that I was going to put it to use in a decent render eventually. It really canes my render times, immensely if using Lux, but since I recently picked up Lorella the Elf and her cute outfit I felt it was the only set that could do her justice. Luckily she uses Victoria 4 textures, so I used the interjections set to add in some decent SSS.
    If you have any tips for better results, I'm all ears... no elf puns intended.
    You have the same issue I did when I started using Elite textures with genesis the inside of the mouth looks lit up. Thought that had been fixed
    Yeah, I found the issue was related to the lighting setup I had, since there are SSS maps in the mouth as well. Hiding the inside of the mouth seemed to make it worse though, not better, since light was effectively penetrating through the cheeks.
    Well, I dusted off my old Texture Converter and decided to start converting the SSS maps for K4 since I do make extensive use of Kaelyn and Ella textures for children. Initial results aren't too bad, but there's always room for improvement. The K4 textures generally aren't very detailed, since getting photoreal images of children has too many legal hurdles to jump. As a result, the only way to really get good results is to use adult textures, but that has it's own share of problems since younger skin has far fewer imperfections and tends to be a lot smoother.
    One day perhaps I'll find the holy grail of K4 textures but until then I'll be happy with Kaelyn. Here she is with the interjection maps converted for her.
    1000 x 1000 - 484K
    520 x 1000 - 231K
    Post edited by Herald of Fire on
  • RogerbeeRogerbee Posts: 4,460
    Looks good,
    I hadn't really noticed the inside of the mouth with the HSS, I don't tend to add it to the inner mouth and haven't really paid attention to any Elite presets in that area. I'll have a look when I open DS up again. I'm committing my energies to a non 3D project right now and want to get it done no matter how long it takes. I can't afford to get sidetracked as I totally lose focus on the project.
    CHEERS!
  • BobvanBobvan Posts: 2,653
    800 x 426 - 183K
    800 x 426 - 195K
    Playing around more with using the interjections on K4 and came up with this. It's probably the first time I've used Sadie and K4 in the same render as well.
    1000 x 1000 - 732K
  • ps1borgps1borg Posts: 12,776
    Foregive me, haven't posted anything for a while, been wrestling with animating this wolf with a LAMH fur coat. Think it is getting kinda realistic (believable?), although I think I'm going to add reflect to the coat if I can figure out something lightweight.
    1500 x 628 - 107K
    Aww, cute!
    CHEERS!
    Very nice,
    I will do similar with Garibaldi hair on a werewolf when I get round to it. I also want to turn the Genesis Gorilla into a proper King Kong.
    CHEERS!
  • ArtiniArtini Posts: 10,571
    Looks like the free LAMH player for DS 4.5 Pro is working well
    http://www.daz3d.com/forums/discussion/17802/
    Below is the DS 4.5 Pro render of V5 Lora and the free Tina Turnover hair available from:
    http://www.furrythings.com/presets/
    In the LAMH player I have applied one of the available Human Hair shader presets.
    Rendering Time: 4 minutes 18.12 seconds
    1024 x 1024 - 449K
    Interesting,
    I asked Catharina from Mec4D about hair a while back and she wasn't impressed with LAMH and preferred Garibaldi. I have yet to try it for myself, but definitely aim to.
    CHEERS!
    800 x 426 - 175K
    800 x 426 - 180K
    800 x 426 - 278K
    800 x 426 - 188K
    800 x 426 - 177K
    edited March 2013
    I also like Garibaldi, but since there are a lot of free LAMH presets available right now
    and LAMH player is free, why not to use both tools, dependent on the actual needs.
    Another example DS 4.5 Pro render using Genesis Extra Long Hair preset on V5 Lora.
    Rendering Time: 6 minutes 7.70 seconds
    1024 x 1024 - 310K
    Post edited by Artini on
    Looks good,
    Mmm, I might look into LAMH.... we'll see....
    That said, I suspect Garibaldi hair will have more presets soon, it's only just out of beta.
    CHEERS!
    Bobvan said:
    Nice,
    When this thread hits 98 I'm starting a new one. That's just in case I don't get a notification and you lot hit the 100 page limit without giving me chance to start a new thread.
    CHEERS!
    Just post a link when you do
    Ok, will do.
    CHEERS!
    Let's help this thread along to 98 pages then. Here's Ella, mixed with a little Josie and the new Daydream dress and pillow.
    1000 x 1000 - 666K
  • DireBunnyDireBunny Posts: 556
    I'll be bad and cross post a picture i did earlier in another thread.
    "For a few credsticks more."
    1404 x 900 - 484K
    Great renders both of you!
    Mmm, what to call the new thread......
    CHEERS!
  • TheWheelManTheWheelMan Posts: 1,014
    Rogerbee said:
    Ok, will do.
    CHEERS!
    You'd better get this one locked then when you start the new thread. Otherwise, you may wind up with some people posting to this thread too.
    Well, 98 was just to remind me to start a new one before 100,
    There can be a handover when we get this to 100, it should lock itself then, unless the limit isn't 100 pages now...
    CHEERS!
    Nice renders everyone some night mood lighting
    discuss
    800 x 426 - 122K
    edited March 2013
    I let these run just under 2 hours Luxrenders
    Close up
    Very minor nudity http://fav.me/d5xbd9h
    800 x 426 - 123K
    Post edited by Bobvan on
    Yeah, looking good,
    We'll see what happens at 100....
    CHEERS!
    So, Bob, what do you reckon to this!?:
    http://www.daz3d.com/luxus/
    Interesting.....
    CHEERS!
    More options the better. If you read the Reality board at rendo its not as good. I am used to Reality but in the end another option to use the Luxrender. may prove easier for some.
