Star Trek Builders Unite 3 “Runtime Amok”
1252628303150
  • mylochkamylochka Posts: 168
    Ok, here's an attempt at adding some bumps around the ear. I couldnt get much detail along the jawline because of the mesh I guess. If this works for everyone then I'll upload it soon.
    David
    Oh, yes!
  • TimbalesTimbales Posts: 2,448
    Was playing around with Sculptris and came up with this vorta like morph. I realize now that the ear hole is a little high, but other than that it looks pretty cool, I think.
    David
    that looks really good
  • GRFK DSGN UnlimitedGRFK DSGN Unlimited Posts: 1,124
    For those who wanted it, here it is:
    http://www.sharecg.com/v/67844/view/11/Poser/M4-Vorta-Morph
    Comments Welcomed...
    David
  • Wolle1962Wolle1962 Posts: 0
    David
    Thank you very much. Can´t wait to try it.
  • Robert FreiseRobert Freise Posts: 4,686
    David
    Thanks Looks good to me
  • blutobluto Posts: 915
    ok i think i got something i can work with . exported object out of poset and imported it into sculptris played around with the morph , imported it into the paint app of sculptris and painted a black and white klingon texture saved out the texture for use as a bump map
    830 x 515 - 33K
    830 x 515 - 33K
    512 x 512 - 50K
    1024 x 705 - 66K
  • jaguarry3jaguarry3 Posts: 230
    Paul's request for a larger TOS era Romulan bridge set me thinking . None of the Romuan bridges had seats so all the consuls would be standing only and of course you would need to incorporate a central periscope unit. Just playing around in Hexagon this is what I have so far. ignore the garish colors I am just setting up seperate walls so i can have different views. Comments suggestions welcome
    1518 x 938 - 388K
  • RedfernRedfern Posts: 1,647
    Say, Bluto! That's pretty slick work!
    Nabbing your bump map and using no morphs, just your texture plugged into the bump and displacement channels, I was able to whip up this. (Ignore the mismatched ear.)
    Sincerely,
    Bill
    375 x 475 - 32K
  • edited December 1969
    OK...I need an opinion here. I have been working on adding the uniform stripe to the M4 and V4 uniform textures put out by jedman67. I think I may have cracked the code on the M4 uniform, using his TWOK uniform as a template on how the stripe should be shaped.
    If it's good enough, I'm tempted to put them up on ShareCG - it's two replacement files (the diffuse and bump) and notes on how to change the diffuse color of the appropriate segment of the tunic.
    Thoughts? Be gentle. This is my first time doing anything like this.
    1387 x 786 - 493K
    i think that looks sharp, adds a nice detail.
    Sincerely,
    Bill
    that looks pretty slick bill .
    it could almost be one of the undiscovered country cookie cutter klingon ridge patterens
    i just wish that there were more and better paint tools built into sculptris.
    as it is i had to take it into gimp and blend and smooth the map a bit .
    oh well at least now i have a kind of way to add an extra level of detail on top or my morphs
    . its a bit tricky though , i got most of that by trial and error, but as they say practice makes perfect and as i do more the better they will get .
    stay tooned
    bluto
    I'm sure zBrush could do better, but that program is just out of my budget range.
    David
    david , dont feel all alone i would love to own zbrush as well , but it just costs too much.
    right now in saving my pennies for poser pro 2012 and that is even a little too pricy for me but it has features i really want to learn how to use and i will work with genisis once you get the plugin from daz
  • rdudarduda Posts: 586
    Off topic, Can any one convert a Max file to .OBJ?
    1010 x 1357 - 607K
    David
    I think it looks really good and responds well to mixing with other M4 morphs.
    I don't know how you create these, so this suggestion may be impossible to implement, but here goes.
    Could you do a 'no ear's morph, then concentrate the Vorta shape only on the areas where the face texture is? That way, a bump map could be made to give the look of the horizontal ear ridges without competing with the ears where it would get all distorted?
    600 x 600 - 88K
    337 x 400 - 60K
    I can try it and see what happens...
    David
    Yes.
    Do you need it poserized too or would you prefer to do that yourself?
  • PDSmithPDSmith Posts: 715
    nuff said..
    768 x 994 - 632K
    Here's the V4 version (finally)...need to tweak the uniform on this character a millimeter or two, but the cuffs came out as expected....
    1387 x 786 - 775K
    i think that looks sharp, adds a nice detail. .
    Thanks. :) I'm debating trying to develop an admiral's version of each set, although I can foresee the belt and rank being an issue (more the latter - I've not seen a set like there is for the officer and provisional ranks).
    Props to blubeetle3 to pointing me in the right direction.
  • TheCastellanTheCastellan Posts: 711
    A nice shot of some of my main characters. :D
    From left to right:
    Second Officer, Cassy Morrison.
    Chief Medical Officer, Huld Ester
    Ensign Vanda M'Giia
    Chief Engineer Walter "Doc" Varley
    First Officer Zeg
    Captain Laguna Nozaki
    1258 x 870 - 1M
    ok so now the dreaded spoonheads and the poor downtrodden ridge nosees con go at it on equal terms
    835 x 499 - 24K
    835 x 499 - 26K
    796 x 637 - 47K
    Nice Job!!
    Hey TimG
    Is this what you had in mind?
    David
    1357 x 1900 - 889K
    that looks good!
    609 x 669 - 352K
    669 x 669 - 372K
  • edited March 2013
    I must possess this, along with the Bajoran phaser.
    p.s. Bluto, check your PMs.
    Post edited by blubeetle3_c656fcc6f5 on
    edited March 2013
    Very nice
    mylochka thank you nice work
    Finally the site decides to let me post
    Post edited by Robert Freise on
