MEC4D
145791015
  • MEC4DMEC4D Posts: 5,249
    LOL Richard ! you made me smile hehe
    RAMWolff said:
    Is that your love hon?  Handsome man!
    Phil , that is the shape that make it real ,  I edited the materials to reflect closer PBR materials but no SSS , our brain is coded so we know what is human or not and small wrong detail will tell us the difference , skin outside is more flat and simple anyway, more specularity happening on the surface than SSS in general , and you don't need much details of the skin to recognize what is real or not , the shape is the key in first place .
    PhilW said:
    He's a free scanned character from renderpeople.com.  It's funny how scanned people seem to look very realistic, even with relatively simple materials, while with all the sophisticated tools that Daz has at its (and its users') disposal, it seems more difficult to get to the same level of realism. I'm not really sure why!
     Next week , can't tell the exact day as we don't do it here anymore , it is Satin 85 PBR shaders for iray .vol.4 double tread shaders .. very cool !
    Just coming into this thread, so sorry if it's already been asked, but when can we expect PBS Shaders 4?
    we can still tell that something is scanned or real , mostly on the eyes but so closer than ever before and it progress
    PhilW said:
    Yes, that's true. I also think that the hair being scanned as part of the head rather than being an addition may have something to do with it, and the natural fit/lay of the clothes. Hell, today's figures are so much more realsitic than when I started in 3D it is unvbelievable, but it just shows that there is still a little way to go.
  • chachahchachah Posts: 27
    MEC4D said:
    That's great people need to learn more about and correct use them for that reason I included my standard lenses presets reflecting my real lenses I use daily , I hope you cover the correct DOF usage with that on top , post link when you are done .
    chachah said:
    In fact, I made this scene intending to demonstrate the perspective deformations related to focal length (here it's a 20mm lens). I'm working on a tutorial about the usage of focal length and the various lens distortions available in DAZ Studio + iray. For instance, here you can see the same scene with a "ptlens" distortion applied. This tutorial will be available at DeviantArt asap (probably next saturday).
    Hi MEC4D,
    As you suggested, here are two quick tips about the correct use of environment maps that I'm happy to share.
    Have a nice day.
    1024 x 2497 - 418K
    1024 x 5100 - 866K
  • nonesuch00nonesuch00 Posts: 18,822
    chachah said:
    Hi MEC4D,
    Have a nice day.
    very nice, thanks
    Very good info , thanks for sharing , in some cases as some of my HDRI allows you can  still use DOF even with ground as in the renders below , but for that the area need to be clear like a beach sand or field or parking lot . You switch to Infinite Dome with Ground , set the ground textures for 70-100  DOF on , camera stright , since from angle even with real camera shots the ground will be always blured as the focal distance don't allow it
    as you see in the Beach HDRI , the change of the focal distance works together with the HDRI as well
    Infinite Sphere with ground is not perfect solution but always something to play with
    chachah said:
    MEC4D said:
    Hi MEC4D,
    Have a nice day.
    1920 x 1080 - 924K
    1920 x 1080 - 1010K
    1920 x 1080 - 823K
    1920 x 1080 - 991K
    1920 x 1080 - 1M
  • xyer0xyer0 Posts: 6,400
    @MEC4D Hi Cath, Joseph here: I have not been able to get your free HDRs (thanks!) or Gardens Vol. 1 - Megapack to appear in renders or in the Render Settings - Environment tab.
    I click on the thumbnail button. A box appears for a second indicating it is loading. But the HDR image does not render with the 3D elements. With all my other HDR packs bought at Daz, all I have to do is double click to load. What am I not doing right?
    edited July 2017
    Hi Joseph , I don't know why to tell you the truth, as you see here in the thread people render it as well and nobody has issues from my website and there was a lot of downloads, I use the last DS public build, what you can try is looad the scene and go into Environment Setting and see if the HDRI is there and if not try to load it manually and see it it works ( you said it is not there) so the question is , is it loaded at all, I don't know why some people have no issues other do in this case , I even moved the HDRI to Runtime in my last freebie but you said it does not load, I will like to know what is going on exactly but can't recreate the issue myself, but it needs to be fixed for all . So please try to load it manually after you click the HDRI scene and let me know and make sure the Dome is On under rendering settings
    Post edited by MEC4D on
    edited July 2017
    Pardon my ignorance, but how do I manually load it? After I click on it, I go to Render Settings / Environment / Environment Map and click on the small thumbnail. The list of jpegs and pngs comes up, but I can't find mec4d hdr's.
    I got Gardens 4 to load, but the other four don't. I'll try re-installing.
    Post edited by xyer0 on
    MEC4D said:
    ... in some cases as some of my HDRI allows you can  still use DOF even with ground as in the renders below , but for that the area need to be clear like a beach sand or field or parking lot . You switch to Infinite Dome with Ground ...
    You're absolutely right. I didn't mention it because I thought that the usage of infinite sphere with ground, which can be very tricky as shown in the attached image, deserves its own tutorial. I'm working on it.
    900 x 600 - 1M
    You did right each HDRI is in own map all maps located here in their folders : My Library\Light Presets\MEC4D\HDRI Gardens vol1   , Garden 1, Garden 2, Garden 3, Garden 4  each of the folder include 2 HDRI high resolution and Low , try to find if you installed all folders with files and ket me know
    Of course not all HDRI will works but with some of them you can  , I wish there was other way to make the ground smaller as not always you need as much area and if the close objects are too close they can get deformed .
    edited July 2017
    I found some better solution for any HDRI , but the ground textures scale is not as it should even if the background don't have any deformation and to fix the ground texture scale you need to use very high focal length  at last 8 mm and use Portrait ratio render format only
    1300 x 731 - 437K
    1300 x 731 - 549K
    451 x 731 - 198K
    451 x 731 - 198K
    Thanks Cath, I will do as you instructed once my current render (CPU only) gets more finished. After I got Gardens 4 (from Gardens Megapack) to load, I was unable to get it to load again. But I'm using Content Library / Products to load. I'll use the Poser style file/folder structure to load instead (like you suggested) and see what happens. It may be that there is some issue with loading from Content Library / Products that causes some to have issues and others (who are using file/folders) to not have them.
    edited July 2017
    That is really possible, try it and let me know, I will be back here in couple hours again and try to load the HDRI from Environment Settings /Environment Map after you load the  scene
    edited July 2017
    I attempted to load via My Library / Light Presets / MEC4D, and the cameras loaded (as they also did through Products), but the HDR does not show up in Render Settings / Environment or in the Image Editor list box. De and re-installing now.
    After re-install, the first Gardens HDR loaded right up, and it appeared in the thumbnail and image list of Render Settings / Environment, and rendered as expected. All subsequent attempts to load other HDRs in the set loaded cameras but no HDR. I suspect that I may have a product installed that is interfering with these HDRs, but there are too many (8000+) to conduct a process of elimination.
    At any rate, if I quit DazStudio and reopen it, I can load a different HDR from the set. But in order to preview another, I must quit/reopen again. Maybe someone smarter than I will suss this out. But all my other mec4d.com HDRs and MEC4D freebies work without a hitch now, although each new one loaded removes the previous one from the image list.
    That is ninteresting , maybe memory issues ? and each time you close the cache clean up allowing you to open another , I would definitelly report it in a ticket to the support as that is very strange behavior of Daz Studio , I don't think that other product interfering with it , here is something else on the hand , if you submit ticket to the support and let them know about the behavior they may know more what is going on as I am total green here in this case , very weird !
  • PhilWPhilW Posts: 5,162
    edited July 2017
    HDRI files tend to be very large, and as you can load the first - whichever one it is - but not the second, then it points strongly to a memory issue. Does Daz Studio have a way to clear from memory anything which is not being used? You could try loading an image with a small memory requirement into the environment (just a jpg), and then try loading the second HDRI.
    Post edited by PhilW on
    In production HDRI Gardens vol2 Megapack "Tuscany Gardens" with 5 HDRIs , some quick tests.
    1920 x 1080 - 484K
    1920 x 1080 - 585K
    1920 x 1080 - 651K
    1920 x 1080 - 789K
    1920 x 1080 - 804K
    1920 x 1080 - 663K
    1920 x 1080 - 661K
    1920 x 1080 - 816K
    After hours of experimentation, finally I got it ! Here's a shot using a 200mm F:5.6 lens with DOF enabled; as you can see there's no distortion at all and the scales are correct. In fact I had to adjust the scaling of the character, the finite sphere and the ground all together. Here are my settings:
    • Dome Mode: Finite Spher W/Ground;
    • Dome Scale Multiplier: 60;
    • Ground Texture Scale: 900;
    • I made a group for the character, the hair and the clothings, and I scaled that group at 400%;
    But there are restrictions, if the back-scape shows something like a wall it must be perpendicular to the view axis, and as you already mentioned:
    MEC4D said:
    ... the area need to be clear like a beach sand or field or parking lot .
    And you have to calibrate all the scalings again avery time you chage the field of view, the location of the camera or the focal length.
    900 x 900 - 853K
  • SorelSorel Posts: 1,416
    Cath your hdr sets look stunning, it's so nice to see you releasing stuff again :)
    Very nice result ! try to use  Box with Ground  it works even with very tight space HDRI, of course, each HDRI need different texture ground scaling and Dome Scaling Multiplier but you will get better DOF even with cameras on angles and fewer issues with scaling , Dome Scaling Multiplier can even go to 9 %
    Thank you so much ! Tomorrow capturing my favorite spots in NYC Center Park and streets of Manhattan
    Just to let you know that PBR shaders vol.4 Satin - MERCHANT RESOURCES was just released  https://www.daz3d.com/mec4d-pbs-shaders-vol-4-for-iray-mr
    960 x 1248 - 189K
  • RAMWolffRAMWolff Posts: 10,369
    I now own a copy!  Thanks hon!  XO
    Thank you for the support Richard ! xoxo
  • SimonJMSimonJM Posts: 6,082
    Straight in the cart for me, too smiley
    Awwww thank you Simon ! preparing new HDRI for the freebie of the week
    In production HDRI Central Park NYC , some quick tests.
    1920 x 1080 - 563K
    1920 x 1080 - 556K
    1920 x 1080 - 618K
    1920 x 1080 - 406K
