Tutorial: Adding Surfaces in DS with the Geometry Editor tool
2»
  • DiomedeDiomede Posts: 15,461
    Thank you, Fixmypcmike.  Very useful for kitbashing.  Also useful to use transparency to hide unwanted stuff.  Two tumbs up.  yesyes
  • RKane_1RKane_1 Posts: 3,039
    If you wanted to retain a figure with the special selected area, couldn't you save as figure prop with a different name?
  • fixmypcmikefixmypcmike Posts: 19,720
    Yes, save it under a different name and it retains the new surfaces.
  • Thank you! That's what I was looking for.
  • Thank you! This is very helpful!
  • ThatGuyThatGuy Posts: 797
    awesome and very useful material!  thanks so much it is definitely appreciated.
  • akmerlowakmerlow Posts: 1,124
    Thank you much! Saved me regarding obj import struggles
  • odasteinodastein Posts: 606
    edited November 2019
    Redundant.
    Post edited by odastein on
    In this tutorial, I'm going to show how to add a new Surface (also called a material zone) to an object. I'm going to be using the "Princess Crown Circlet" from Crown Circlets For Any Figure by EmmaAndJordi. This circlet comes with material presets for changing the color of the gems or hiding them, but it does this for all 3 gems. I'm going to create a new Surface for the middle gem, so that I can change it separately from the other two.
    Thank you for the tutorial.
