Ridiculous
2»
  • frank0314frank0314 Posts: 15,013
    edited June 2012
    Because it requires custom coding I think.
    Post edited by frank0314 on
  • SockrateaseSockratease Posts: 813
    Frank0314 said:
    Because it requires custom coding.
    Which just proves what crap this forum is.
    That should be one click in the admin panel.
    Like all the real forum software does!
    This is set up like a blog the way it sorts - with posts treated as comments on the blog entry. Those things work exactly like this forum does.
    We want it just as bad as anybody. It takes us double the time to do our jobs.
    Only double?
    Wow. You're good!
    It didn't start out that way. We've just developed a flow, but keep screaming to get it working right.
  • KhoryKhory Posts: 3,854
    Could be worse..way worse. Seems like CBS changed to a forum similar to this and then when that wasn't loved went to what looks like a facebook add on. I've seen several forums like this over the years. Most never got changed because the company really didn't care if they got used at all. I don't believe that will be the case here.
