WELCOME TO THE 5TH ANNUAL JUNE FREEBIE CHALLENGE!
1131416181930
  • jeeperzjeeperz Posts: 1,102
    jeeperz said:
    been having the same trouble, finally give up and come back later, like the re-vamp. she looks a bit uncomfortable though straddling that tank.
    Yeah, that's what I've been doing. But sometimes it takes until the next day.
    And the hovertank has a thicker canon compared to the original quadtank I'd used last year, even with scaling down. Which is why I didn't list the pose, I had to do far too much tweaking to it to make her sit right.
    I go from like today, I get a page not here from yahoo to the lang page and back and forth until I give up, the other day when I would try to log in, it would not let me, that one was easy, log out and re log back in. but today and yesterday's dilemma if a bit more frustrating, can't even get to the site. even after several attempts. Hope they get the bugs worked out soon
    Like a Hag In A Bag.
    More of a Glamor Shot then classic Pin-Up but close enough I think.
    Unfortunately Cycles made some artefacts and I'm to lazy to fix them.
    Cheers Oom
    looks great Oom, I like the realism it has
    music2u4u said:
    Ok, now I can answer your question. In the past, since .obj format is acceptable, as it imports into DS fine, If something was used to convert another format into an .obj file, it had to be listed, and possibly a link to it. Poseray converts .3ds files and Lord Ganthor has used it a few times and listed a link to it. BUT...the actual program can not be claimed as a freebie. So, the answer would be no, it can not be claimed as a freebie, but if used must be listed along with a link so others can reproduce the item in the render and use it in DS.
    I don't remember seeing the question, and when you asked the other day, I will admit, I had no idea what you were talking about or what this Arbaro even was. I appoligize if I came off as rude. I simply did not know what you were talking about. I hope this clears up any questions you have about third party generators or converters.
    Yes, that clears it out. Well, just to complete the subject: If I use a commercial program to create something I use in a render, it will not be counted as a paid item or...? I think of Photo Shop, Z-brush, X-gen or DCC for instance.
    I believe you misunderstood the question so the answer came out wrong, so lets forget the it and go on with something more pleasant.....
    photoshop is a paid item (I got it for free many years ago) I think most of those post work things would fall under the not allowed thing. I use photoshop to fix pokethroughs and that is allowed to fix pokethroughs, add borders or a signature, it would only count as a paid item if someone has to buy it to get the item you created. If the item can be used free of charge then I think that is ok. It helps to offer the item for free if you have created something, like what I did when I made a character (AJ) for a render. her is the link http://www.sharecg.com/v/45660/view/11/Poser/AJ-morph-for-K4
    Not sure about DDC or X-gen don't know what they are, but z-brush is a purchase item so the answer is probably no Oom, I hope I was able to help clear thing up for you.
    I am getting confuzzled
    500 x 570 - 18K
    :lol: :ahhh: :coolgrin:
    your funny cho, you make me laugh
  • Oom FooyatOom Fooyat Posts: 0
    Cheers Oom
    Wow! I thought that was a photograph! Maybe I need to look into Blender. That's what uses Cycles, right? I remember reading something about it elsewhere. Is that car the Buick Roadmaster by Nationale7 over at Renderosity?
    Dana
    It is a Hudson '49 from Schurbys Old Cars at Rendorsity
    Yes it is Cycles, mCasuals export script for DS makes it pretty simple to use Cycles. But the script do not handle advanced shaders so you will have to do your own, like the chrome and the car paint. The node editor in Cycles works like Shader Mixer. The script exports lights but you should replace them to take full advantage of Cycles. And it is a bit slow, this one took an hour and a half. But I have an old rig and no CUDA support. But it do look good kind of nice once you get everything together (well..maybe not under the bag) ;)
    Cheers! Oom
  • DanaTADanaTA Posts: 13,338
    Oh, I have that, too. It was a freebie, right? Yeah, I have that. 8-/
    Thanks for the other info. I'll try to remember it in the future.
    Dana
    edited June 2012
    photoshop is a paid item (I got it for free many years ago) I think most of those post work things would fall under the not allowed thing. I use photoshop to fix pokethroughs and that is allowed to fix pokethroughs, add borders or a signature, it would only count as a paid item if someone has to buy it to get the item you created. If the item can be used free of charge then I think that is ok. It helps to offer the item for free if you have created something, like what I did:lol: when I made a character (AJ) for a render. her is the link http://www.sharecg.com/v/45660/view/11/Poser/AJ-morph-for-K4
    Thanks for your comment!
    I was thinking of things you use in renders, like textures and backdrops made with PS. DCC, Dynamic Cloth Control, commercial plug-in to DS. X-gen is a paid for tool to transfer morphs form older mill figures to Genesis. You can do the same thing with free or default DS tools.
    chohole
    :lol: I'll try that at work tomorrow, only trouble is it will probably be my boss asking.
    Cheers! Oom
    Post edited by Oom Fooyat on
  • Gloomy007Gloomy007 Posts: 0
    Not one of my better ones, but I though I'd go ahead and post it anyway.
    Call Interupted
    1.) Jinky Teen V4 Character Morph. 3rd From Top.
    2.) Dandra for V4 Textures Only. Registration Required.
    3.) Licorice for V4 Outfit.
    4.) MMBikini Set02 for V4/A4 Bikini Bottom Only. Texture Changed.
    5.) Light Colors for Licorice Textures for Above. Registration Required.
    6.) Koz's Short Bob Go To Downloads at Left of Page, 1st Item at Top.
    7.) M4 Hipster Glasses Registration Required.
    8.) Morphing Pillow Top of Page. Original Untextured, Texture Added.
    9.) Millennium Cat LE Registration Required.
    10.) Red Tiger for DazMill Cat Registration Required.
    11.) Laptop Computer 9th Item from Top.
    12.) iPhone for Poser Registration Required.
    13.) Plate 3DS Format Only.
    14.) Cookie 3DS Format Only.
    15.) Window Frame 3DS Format Only.
    16.) Window Shade Registration Required.
    17.) Hidden Ally Background Planar Registration Required.
    18.) Ice Cream Props Milk Shake. Scroll Down to 2nd Image for Link. *
    ( * Denotes Items Required for this Challenge)
    No Longer Free: DAZ Victoria 4 Paid For: Victoria 4 Morphs++.
    As always, figure set-up in Studio 2.3 and final render in Bryce 5.5.Some minor tweaking of elements that were shader dependant and did not transfer over to Bryce.
    All 3DS Models were converted to .obj format for import into Studio using PoserRay, available Through This Link Converts Lightwave and 3DS files into easy to use .OBJ format files. Free and easy to use.
    LG I actually think you done more than good ;) love this one.
    A HAG IS BAGGED!
    Has to be NAE, though, cause I intend to ignore the rule about the model not moving when I unbag her. It's becoming an annual tradition with me. Ignoring the rules, I mean.
    Plus, I already won the Monkeemobile in an earlier challenge, heh heh.
    Hey.. I know when this is going.. saw movies like that :P :P :P Great job Dorsey:d
    dleelaw57 said:
    Hag Bag Entry
    HaggoBaggoed
    dleelaw, may I aks what texture you used?? I really like her knees, they have this realistic touch of othe colour ... (cannot wait to see her unbagged)
    What is with the forum. I log in, I'm logged out, I can't log in, I can log in. :-/
    Anyhow, now for a revamp of last year's entry.
    1 - Bonnie for V4 http://www.sharecg.com/v/23363/Poser/Bonnie-For-DazV4.1-and-Morphs++
    2 - Amanda for V4 (body morph) http://www.renderosity.com/mod/freestuff/index.php?user_id=230020
    3 - Valens hair for V4/A4 http://www.sharecg.com/v/36166/Poser/Valens-Hair-For-V4/A4
    4 - Valens Hair Revisited http://www.renderosity.com/mod/freestuff/details.php?item_id=57025
    5 - Little Dragon's Tube Top and Texture Pack http://littledragon.francemi.net/misc_01.htm
    6 - Studded Sandals http://lmdesign.co.uk/sandals.htm
    7 - Patrol Cap http://www.ageofarmour.com/3d/free/patrol-cap.html
    8 - Dogtag http://www.sharecg.com/v/37822/View/11/Poser/Dogtags-V4-Smartprop
    9 - Ohlala bracelet http://www.runtimedna.com/OohlalaDecoder.html
    (Must have the Circus Decoder and decypher the password)
    10 - Female Glasses 3 http://lab108.x0.com/lab108/accessories.html
    11 - Road http://www.sharecg.com/v/41284/gallery/11/Poser/The-Streets---Part-01
    12 - Wall front http://www.sharecg.com/v/41337/gallery/11/Poser/The-Streets---Part-02
    13 - Mega City - Block 1 http://www.sharecg.com/v/26105/gallery/11/Poser/Mega-City---Block-1
    14 - US Pickup Truck http://www.sharecg.com/v/32601/View/11/Poser/US-Pickup-Truck
    15 - H4 Hovertank http://www.daz3d.com/shop/h4-hovertank/
    16 - Cooler & Tyre tube (in tray of ute) http://kctc.francemi.net/KCTC_Beach_2010/pack_02.htm
    17 - Champagne bottle http://trumarcar.francemi.net/foodprops_tc.htm (Amongst 'Pinic Food')
    18 - Trash Bag http://trekkiegrrrl.dk/prp2.htm (2nd from bottom)
    19 - Morphing Puddle http://www.sharecg.com/v/18189/View/11/Poser/Morphing-Puddle
    20 - Dyald's Light Set2 (Sunny) http://www.sharecg.com/v/33904/Poser/Dyalds-EZ-Lights-2
    21 - Apple Core (in front of trash bag, probably a bit small to see) http://www.sharecg.com/v/18220/gallery/11/Poser/Apple-Core
    *Sharecg and Rendo sites require registration*
    Rendered in DS3A. Signature added & image resized in PSP7.
    MIA: Fisty's Liquid Shaders (I've no idea how to get them from the archive :blank: )
    Paid Item: Morphs++ & Alicism (the Shorts)
    Title: Hover-Boom
    Great job Assasin. She is a bomb :)
    Cheers Oom
    You are going to tell me this is render??? I mean .. really?? I was convinced it is a picture.. you need to give me some links to the Cycles for summies, or something because I want to do that to....
    Call Interupted
    A HAG IS BAGGED!
    dleelaw57 said:
    Hag Bag Entry
    HaggoBaggoed
    Title: Hover-Boom
    Cheers Oom
    You are going to tell me this is render??? I mean .. really?? I was convinced it is a picture.. you need to give me some links to the Cycles for dummies, or something because I want to do that to....
  • Lord GanthorLord Ganthor Posts: 592
    jeeperz said:
    ok LG NO MORE RENDERS for you, that's about enough of the stiff competition... LOL another great one as always
    No more? Gee...then what am I going to do with the other 5 I'm holding back? Y'know, the Real Man is gonna be really disappointed....;-)
    Is the Real Man going to pose for a pinup render ?
  • deeleelaw57deeleelaw57 Posts: 1,478
    Krissy said:
    dleelaw57 said:
    Hag Bag Entry
    HaggoBaggoed
    The character is
    Annalise for V4
    But it appears it is no longer available from this site.
  • ZamuelNowZamuelNow Posts: 753
    DanaTA said:
    ZamuelNow said:
    I'll be donating this dial spun character morph as a prize to the contest entrants. People seemed to comment on it positively when originally shown a couple months back so I figured I'd share. Gonna make a few small tweaks to it plus, since it's a Genesis morph, I'm going to attempt to make metadata for it by the end of the month so it shows up in Smart Content.
    She's nice, a good ethnic character! Unlike the many cookie-cutter Barbie dolls. After a while they all start looking the same. Is it for Genesis base, or is V4 required?
    Dana
    Doesn't use the M4/V4 shapes but it does require the basic Genesis Evolution morphs plus the free conversion of DieTrying's morphs for Genesis: http://www.sharecg.com/v/58198/View/11/Poser/DieTryings-182-V4-Morphs-for-Genesis
    Well...now dat y'mentions it...
    What's Summer Fun mean t'me? I'll tell ya what it means t'me! A weekend at Coney Island! I mean, wott more could a Real Man ask for? Ya gots your beer, ya gots your brats, ya gots your beach an' a'course ya gots your babes! Dere ain't nuthin' better den draggin' th' ole grill on da bus wit a cooler full'a meat and a few cases of your bestest brewskis for a relaxin' weekend inna sun an' soif! I feels sorry for you chumps wott ain't gotta beach nears by wit da sand and da salty ocean spray! So, if youse guys will 'scuse me, I gots some serious eatin' an' drinkin' t' 'tend to. Everybody have a safe 'n' happy summer!
    1.) Shawn for M4++ Character Morph. Registration Required.
    2.) Moustache 19th from Top.
    3.) Mitch Hair
    4.) M4 Laced Shorts Registration Required.
    5.) Cigar M4 Smartprop Registration Required.
    6.) The Fedora Registration Required.
    7.) Beach Chair and Parasal 4th Item from Top. *
    Cooler 3rd Item from Top. *
    Beach Toys 2nd Item from Top. *
    Drink Props Only Link on This Page. *
    Beach Signs Bottom of Page. *
    8.) Hot Dog Scroll Down to 16th Image, 1st Link. *
    Hamburger Scroll Down to 16th Image, 4th Link. *
    Cake Cake Prop.18th Item from Top. *
    9.) Patent Beer Bottles Bottom of Page.
    10.) Picnic Table Registration Required.
    11.) Grill 3DS Format Only. Converted.
    12.) Poseable Pizzabox with Pizza 7th Item from Top.
    13.) Beer in Schooner 15th Item from Top.
    14.) Street Lamp OBJ Format. Registration Required.
    No Longer Free: DAZ Michael 4 Paid For: Michael 4 Morphs++.
    Background Photograph Located At This Link Copyright by the respective artist.
    Anna Happy Annavers'ry...t'me, dat is. I bin hangin' 'round wit'chu folks for a whole year now an' it's bin a lotta laughts I gotta tell ya. Sees ya' next month!
    750 x 600 - 401K
    I tend to "correct" things so I can't really do the Bag a Hag but I did decide to experiment with a render with a more mature pinup model. Listing this as a NAE from the main June entry since there's nowhere near enough freebies plus it slightly pushes the number of paid items.
    700 x 687 - 48K
    Oh, we've got to have an appearance by da Real Man! :-)
    Dana
    ZamuelNow said:
    Dana
    Oh, well I don't have the Evolution morphs. Maybe some day.
    Dana
  • Alisa Uh-LisaAlisa Uh-Lisa Posts: 1,310
    Love this!
    Nice renders, all!
    http://www.daz3d.com/index.php?&ACT=50&fid=41&aid=4664_xUTJha87CZa6jC7J0OB0&board_id=1
    Great! So funny, it all fits right in, too!
    No challenge is complete without an appearance by da Real Man! :-P
    Dana
    NAE or not, it's a nice render Zamuel! Interesting pattern on the white stripes on the road.
    Dana
    well we HAVE to have a real man, render...what would the forum be without him...... after that
    3.) Mitch Hair
    ahhhh.... pizza, I just made some for dinner. from scratch
    now that's a sight we all want to see
    very pretty Zamuel
    guess I'm going to try staying logged in and keep the page up to see if it changes things with the bugs.
    Dana
    yeah forgot about him, gotta have him in here, especially if LG does a pin-up with him
    Dana
    Hmm...that got me thinking. In the spirit of this being a freebie contest, I went ahead and redid the dial spin only using the options from the free morph set. Not exactly the same due to differing options but it works well enough. Attached an image of the face of the morph (skin texture not included) though the morph is full body.
    Now that I think of it, I might be forced to do a morph that's just the head...
    700 x 687 - 27K
    700 x 687 - 25K
    That's very nice, Zamuel! And it's nice of you to do it with no pay item dependencies.
    Dana
  • music2u4umusic2u4u Posts: 2,822
    edited June 2012
    3.) Mitch Hair
    WOW...what a hunk!
    all links are good. You have the required Trumarcar freebie. You have the required 12 beers!!!! You are good to go.
    750 x 600 - 401K
    Post edited by music2u4u on
