Hexagon Bridge problem
I have a weird one. When I try to send something out of D/S 4.5 to Hexagon, via the bridge, I get the message : "The Hexagon Bridge requires Hexagon v2.5.1.52 or higher."
But, the version I have is v2.5.1.79, so it should work, no? However, when I look at the info for the program, there is no version number listed. I only know what version I have from the program start up splash page.
Note: this is on the Macintosh version.
Any fixes? Anyone know where I can look to see if the version number is missing on this distro?
Where are you bridging to?
I solved this eventually by reinstalling Hexagon. Apparently it matters in which order the two programs are installed.
Ok. I see now you were doing Hexagon. So it works in both directions?
