Render grey characters
How do I render grey characters (ie without skin) but having bump and/or normal map effects?
Thanks in advance
    Just remove the diffuse maps. Those are the 1st in the list for every DAZ model I've seen in the Shaders tab section to the right of your viewport.
    Check Translucency Weight and Color also.  Setting Weight to 0.0 is the shutting it off so you don't have to remove any textures or reset color to white in the Color slot but why leave them to tie up memory.
  • Oso3DOso3D Posts: 15,119
    If you use Iray, and pick up my free Iray shader pack, in Art there is a 'flat white' shader which makes surfaces a simple white color.
    You can also make your own and save as a shader preset
