Update / New Install - Error Message
Hi,
I can't seem to install the new Version of DAZ Studio... even though the old Studio is now completley uninstalled, I even uninstalled the Standard Content separately after the errormessage I got... didn't solve anything though...
Does anyone know how I can solve this? The Error-Message is attached to this posting...
Thanks in Advance!
  • Richard HaseltineRichard Haseltine Posts: 111,414
    Older versions of DS installed some basic content, that has now been moved to serparate packages.If you still have the isntaller for that, or a, older version try installing through that, then install the newer version. Alterntively you could try removing the content uninstaller.
  • BlazeMystEraBlazeMystEra Posts: 466
    Thank you Richard... the simplest possible solution it was... just remove the uninstaller and all's good again. :)
