Inserting text.
Cat_Dancing
Is it possible to insert text into the final render.
Thanks, have a great day.
Cat_Dancing
I think there are one or two sets of prop letters, or you could add the text as an image to a primitive plane or cube.
Thanks for the input Richard, certainly worth persuing. What I am trying to achieve is a short explanation about the content of each render. I guess it may have to end up on a separate page in the final publication.
Hope you're having a good day.
You can always pull the render into an image editing program if you don't want to use a separate page.
Hi Fastbike1 - Thank you for your input, most helpful.
Have a nice day.
Depending on the style you're after, this: http://plasq.com/apps/comiclife/macwin/features-galore/ is probably one of the easiest ways to add text to images. The publishers give you 30 days to try it out—quite generous these days—and it's only $30 if you decide to buy.
