Carrara Non Photo Realistic Works
12122242627100
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Stezza said:
    select the blending mode... leave mouse pointer there and scroll away.... seeemples cool
    Thanks for the pic.  But my mouse must be set up different from yours.  Doesn't work, unfortunately.
  • HeadwaxHeadwax Posts: 10,514
    edited June 2017
    Stezza said:
    that's why I can't stand sitting around for an hour or more rendering with iRay or the other ones as I always take it into PS and change evrything anyways...
    I did a render the other day... took over two hours.... I had other things to do and when I checked later that's what it took.... big waste of my time if I wasn't doing something else as I loaded it into PS after and changed it all with layers, brushes, erasers and anything else I can use... I noticed in a few posts in the commons the discussion on V8 was that most are happy to push the button in DS to do it all... that's when you get the same as same as.. to each their own though I guess.
    yes, same same same
    I've been fortunate to have plenty of feedback from lots o f well known 'places' -
    my feeling is that there is a big movement against 3d looking work (in publishing)  - hence my efforts to try and learnt to get away from ' the look'
    Iray renders are so good they are starting to look photographic - there's nothing so boreing as perfection
    that's what I told my dentist when he offered to fix my teeth.
    Post edited by Headwax on
  • BC RiceBC Rice Posts: 591
    Didn't want to start a new thread since it's really only pertinent to NPRs, but I've seen a few folks struggle with line renders. Thought I could save a few folks here some headaches. If you're using a 3rd party program to get your line art (which you probably should) you'll want to make sure to have a color blocked version of your renders. Doesn't take much time. Just use flat colors. Then use your 3rd party line render and the Multiply the layer over your base render. And make sure to save your Global shaders in the shading bin.
    4032 x 3024 - 6M
    edited June 2017
    Great advice - thanks Mr Rice :)
    Today's sillyness from me: An offshhot of an Advent Calender I did a few years ago for our City Council.
    Fort Scratchley is one of our tourist attractions.
  • Bunyip02Bunyip02 Posts: 9,302
    Like it
    V4 and V8
  • PhilWPhilW Posts: 5,162
    Clever title - and great image too!
    Thanks Bunyip02, great image the bonnet up is a good compositional thing.
    head wax said:
    I've been looking at a lot of 'npr' work in different threads and after a while it's depressing
    like M4, you see M4 in a render and you know it's M4 (mostly) morphed.
    From what I've seen a lot of artists are using one photoshop action etc (not Carrara artists!)  and expecting a masterpiece -
    it makes you question your own work because you recognise the style. I don't think I've seen much that really does look 'hand made' - unless it's been worked over by hand.
    maybe I'm wrong :) hope so!
    I've read this about four times, each time hoping that I would understand your point.  No luck so far. :)
    Here is what I gather so far:
    1.  M4 and standard morphs are overused.
    2.  People use a single photoshop filter and expect a masterpiece.  (Aren't some Carrara artists doing this as well?)
    3.  You question your own work because you recognize the style?  Lost me.
    4.  Not much looks "hand made" unless it has been worked over by hand.  (filters alone aren't cutting it?)
    5.  You hope that you are wrong.  About what?
    Any clarification is appreciated!
    ha ha, well that's me, I type and then I think
    let's see... the first time I saw this  https://s-media-cache-ak0.pinimg.com/originals/f9/3f/d2/f93fd22e34060218ff934c95d79a2b12.jpg
    I was in love, I was 19 I think. But then later on I realised I hadn't seen the real thing, just a bad copy....
    So the moral is, the more you listen to a song that you thought was terrific, the more you hate it ...
    Let's see, forget about that. :)
    I think it's about secrecy of genesis and the diminshing theory of ice-cream cone satisfaction.  The more ice creams you eat in on session the less you enjoy them.
    Once you pin the butterfly down then you have killed it's beauty.
    Okay, that's just blah sorry....
    But seriously.....
    1) You need to use a figure for a while to recognise the cliches.
    2) Carrara artists? Not that I am aware of.
    3) It's good to question your work. When I say 'style', I means that I can see in my work filters that others are using. I would prefer it if it the genesis was hidden.
    4) A combination of filters will cut it ..... some of the time, if used with subtley?
    5) I hope I am wrong that only hand made stuff looks hand made. :)
    Have a look through this excellent thread and try and identify the filters that are being applied :)
    https://www.daz3d.com/forums/discussion/54697/non-photorealistic-renders-npr#latest
    I guess the beauty of Genesis is that the morphs are pretty endless
  • cdordonicdordoni Posts: 584
    Re. 3) You could make your own filters :)
    Re. 5) I think you are right, only handmade stuff does look handmade. Randomization and noise only go so far ... they are predictably unpredictable. Its very amazing that we can almost instantly tell when something is not handmade. Somehow we innately identify human imperfect from mathematical processes.
  • StezzaStezza Posts: 8,984
    edited June 2017
    typical Australian.... I understood it all frown
    now where did I put that chocolate milk..... hmmm
    Post edited by Stezza on
    HW, thanks for attempting to explain.  I got most of it.  As always, I enjoyed hearing your thoughts.
    I suspect that you are using the term "genesis" in two different ways?  One is in reference to the genesis character, and the other is...(the secrecy of genesis)?
    3) good point - :) I might be better at 4) though - my hand is steadier than my brain :)
    @Stezza, sorry there was some truth within the mud :)
    edited June 2017
    bit of topaz and multitude layers of post work
    2855 x 3000 - 1M
    edited June 2017
    Hi UB. sorry just saw this! Ah yes Genesis and genesis :) The non capital  'genesis' as 'the begiining' of. (Sorry for ending a sentence in a preposition there)
    Not that I am biblically minded.
    2855 x 3000 - 5M
    Nice, prefer this one.
    edited June 2017
    Dogfight - Toon! part III then Filter Forge Chinaware painting filter
    800 x 600 - 1M
    Post edited by Bunyip02 on
    edited June 2017
    loving these posts.... heart yes
    800 x 600 - 262K
    wow those two work together hand in hand :) must try it!
    ha ha ha , knowing the genesis for this makes it even funnier - and the rebranded ice-scream (Peters?) :)
    edited June 2017
    almost on topic,
    this well known Australian Artists uses Carrar to design some of his sculptures then 3d prints them and assembles them, then paints them (/.I think)
    here's a link to his latest show, you have to be looged in on facebook to see them sorry
    https://www.facebook.com/fred.braat.1/media_set?set=a.1395672867180625.1073741866.100002137752769&type=3
    can't see that link.. it must be a personal page frown
    Sorry Stezza , it's interesting work, I'll ask him to make it public.  . . It's important because he is taking things a few steps forward. Like yourself.
    Excellent - then there is strawberry milk, bannana flavoured milk, lime flavoured milk, and that great staple coffee flavoured milk.
    edited June 2017
    Dinokonda & Hydra - Filter Forge - Old Book Illustrator filter
    Bunyip02 said:
    Dinokinda & Hydra - Filter Forge - Old Book Illustrator filter
    I'm adding this one to the best of Bunyip Pile.
    edited June 2017
    Todays render - Blue Dragon & friend - Filter Forge Chinaware painting filter
    800 x 600 - 1M
    Off Road - Filter Forge Chinaware painting filter
  • DiomedeDiomede Posts: 15,410
    Chinaware, have not tried it myself.  Now that is a fun one!
