Creating a grid of Cubes
Analog-X64
Hi Everyone,
I want to create a grid of cubes lets say 10 cubes x 10 cubes. I could do it by hand, but I'd like to make it perfect and symmetrical.
I did some searching and didn't find anything specific.
I did find instancing lab tutorials, but that didn't work well.
Anyone know the best way to do this?
Thanks.
Use the 'Multi-Replicate' function.
Create your first block (eg: 10x10x10) and place it top left of where your grid will be created.
Go to Multi-Replicate (Under the 'Edit' menu)
Set quantity to 9 and Offset on Z axis to 15 (this will leave 5 units between each block)
Click the tick.
A row of block will be created evenly spaced out. Select the row (it's handy to group them too)
Go back to Multi-Replicate.
Quantity should still say 9, if not, re-type 9 in that box.
Set offset on X axis to 15.
Click the tick.
You've now got a grid of 10x10 blocks with a space of 5 between them.
Hope this helps.
Thank you very much. That helps a lot !!! :)
The answer was right in front of me and I didn't realize it was so easy to do.
I'll post my final render so you can see what I have in mind. :)
Thanks again.
Here is the first result of what I've learned from creating grids from this thread thanks to TheSavage64's assistance.
@Analog: That's a real interesting image.
I do have other images that I post on various gallery's. I'll post some on the sticky renders thread.
Now that's an abstract if I ever saw one. ;-)
It does indeed, thank you :)
Rendered with TA lighting at 64RPP.
