Non-photorealistic Renders (NPR)
15051535556100
  • mmitchell_houstonmmitchell_houston Posts: 2,535
    edited June 2017
    And just like that, I have something I'm interested in... This has potential. This fixes the loss-of-focus problem I was having with the previous version.
    The obvious problem with this is the face on the attacker. I'm very close to giving up on this altogether, but a previous version of the illustration is already in the book, and replacing it would mean resetting the entire page to ensure that the new image fits. Plus... I don't really have anything else ready to take its place.
    I think this size is closer to the actual printed size, which explains why I went with such bold ink strokes. When it was displayed full-size, the inking was overpowering, but at this scale, you can see that it's not really all that bad.
    Print scale is one of the most frequent issues I see with a lot of the NPR work in this group. Most of the sketch looks would only print as full-size illustrations. In most cases, the sketched lines would close up and just become an odd gray-scale effect if actually printed in a book. Now, for online work, that's not an issue. But if you are thinking of taking your work to paper, scale is something to think about.
    Another question: On the attacker's outstretched arm, I think I need to decrease the shadows on the top of his arm and increase them on the bottom. Do you guys agree? The dual lighting rig I use creates accurate shadows, but there's something off about how they are layered in this illustration.
    Post edited by mmitchell_houston on
  • Artini said:
    Kheiron - https://www.daz3d.com/fwsa-kheiron-hd-for-genesis-3-male   in front of the castles from Unity Polygon Knights Pack.
    This is a very cute illustration. I like the simplified colors, and the simple geometry definitely takes it to NPR territory. Although... it kinda has a video game look to it, I think kids would dig it in a story book. I definitely like the moutains and clouds. Compositionwise, the centaur is lost next to the well/fountain. In a wide shot like this, I would suggest moving him significantly forward so that we can see him more clearly. After all, we don't need him to establish scale because there are steps and doors in the illustration. And consider why we're seeing so much lawn and so little sky; the illustration horizon line seems to be a bit high. Finally, think about the colors of the flags. Are they they so muted because you're sticking with a muted color story of blues, greens, purples and cool colors? In white, red or yellow, they would "pop" more than they do now.
    Anyway – great job. You are really making headway with this particular style!
  • JOHNGARRETTJOHNGARRETT Posts: 127
    This one is a comic I did a ways back as a sort of promo for the upcoming sci-fi novel that I still haven't finished (just never seems to be enough time in the day).
    The character is a Genesis Neo that I modified - I'm usually a big fan of the Raiya characters. The alien is a modified "Kuril" figure from The AntFarm.
    I did my compositing in Photoshop and the text in Illustrator.
    I also ended up making a quick animated comic out of it in Blender both for fun, and because I wanted to learn the Blender sequencer. At the time I did it for Instagram and it had to be under 15 seconds so it goes a bit faster than I would like, but I thought it worked out. I don't think I can embed an Instagram post here, so here's a link: https://www.instagram.com/p/q72c05AUyS/
  • HeadwaxHeadwax Posts: 10,562
    head wax said:
    head wax said:
    Thanks for the heads up on Old Book Illustrator Bunyip02
    Here's a few Carrara Render passes worked up with Topaz and then using Filter Forge Old Book Illustrator
    Hmmmm. In general, I like it. But there is a strange discordance between the foreground and background. Particualrly in the area of his trousers. The color treatment and shadows are really intresting, though. I'm interested in seeing where you can take this.
    thanks, yes, the upside down v between the legs... I tried a few tonal values and nothing seemed to work. Nice point about the trousers - I think the textures are causing the discordance. ?? hard to say. I think losing the vine pattern at back left would help too. Moral - always render background in a different pass :)
    I think the textures on all of his clothing are problematic in this treatment. They're just too busy and they are distracting because they have the same tonal weight as the background. I think you either need to do a color overlay on the figures, or drop the textures. Right now there's just not enough contrast to make the illustration work. I do like the character design, though.
    yes, you are very right, thanks for that/those observation (s) !
    I think the arm looks fine as it is. Maybe just post both versions here :)
    wow that's super clean, really enjoyed the animation - I think it adds a lot to the story
    edited June 2017
    Here's a Carrara render. In post work I  mainly using depth pass, shadow pas,s toon pro pass, coverage pass and Carrara's  NPR - which I revisted after seeing @Vysur's excelent image in the Carrara forum..
    In Carrara the toonpro pass, the coverage pass and the NPR pass all give different lines. The toonpro is an extra plugin - the others are native to Carrara.
    Postwork with Topaz and overlays by Fotosketcher.
    cheers :)
    Post edited by Headwax on
  • Oso3DOso3D Posts: 15,114
    I tried to do this in 3dl, but kept running into problems. I had INTENDED on doing some intense godrays coming over the horizon but I couldn't get it to work right. Meh.
    1748 x 1080 - 545K
    great image though - only thing that doesnt gel is the woman looks flat
    edited June 2017
    Carrara render - topaz work over. Used a shadow catcher to superimpose on a previously rendered background.
  • ArtiniArtini Posts: 10,808
    Thanks again, mmitchell_houston, for all very useful insights and comments.
    I have placed centaur there, because it was in the point, where the lines from
    rule of thirds were crossed, but I were also not so happy with the placement.
    Will have to experiment more.
    Looks good to me, @timmins.william! Very much like a painting. So this is done in iRay?
    The only thing I would suggest is to try to add some "atmosphere" over the tops of those hills to make it look like they're farther away, some light blue or white would do it.
    Thanks, @head wax! I'll probably revisit motion comics in the future, too.
    Now this is fantasy illustrated! it reminds me of the stuff I used to see in Dragon and Dungeon magazines back in the day.
    Yeah, I had been struggling to get some good distance haze but ... meh. ;)
    And it's Iray then run through Fotosketcher (which is awesome).
    Here's another Iray + Fotosketcher.
    1748 x 1080 - 685K
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    @timmins.william - four arms, huh?  It took me a few to figure out what was odd in the picture, lol.  It looks good.  Love the mellow colors and the painterly effect.  The sand line might be a little too straight, suggest a bit of variation, but works either way.
    When I'm in a bad mood (which is almost always) my art generally cycles between dark (to vent) and light (to distract myself).
    Here I'm cycled back to dark...
    http://willbear.deviantart.com/art/Stelae-o-684337427
    (mild nudity)
    Thank you Mr Garrett
  • tkdroberttkdrobert Posts: 3,636
    edited June 2017
    Big Fan of the original BSG and the reboot.  Redid this one several times.  Not sure I'm satisfied with it but it's cool nontheless.
    Classic Battlestar Galactica by tkdrobert
    Post edited by Chohole on
    It is beyond cool, @tkdrobert.
    Nice, tkdrobert!
    And another in a series of vaguely Lovecraft inspired works.
    Mild gore.
    http://willbear.deviantart.com/art/Last-Castle-o-684395446
    Carrara render passes worked up in Topaz etc.
    'The Body of Christ, The Tree of Life.'
    It's a follow on to an image I made for a religious prize a few years ago. The first image is now owned by The Uniting Church.
    I am definitely digging the Dragon Magazine vibe (Thanks JOHNGARRETT -- I really digged those back in the day, too!). That is a very interesting item on the ground, and the painterly effect on the face is nice. The shadows don't line up to the feet, though...
  • head wax said:
    Carrara render passes worked up in Topaz etc. 'The Body of Christ, The Tree of Life.'
    Fascinating image. I'm intrigued on multiple levels, especially seeing stigmata on one so young. I'm puzzled by the duality expressed in the body, but the hair seems to be a single piece that crosses the two textures. Is this symbolizing nature crossing the boundry twixt man/nature? Or am I reaching? Nevertheless, fascinating (and when I'm in a better mood, I'll go look at your "dark" illustrations – this just isn't the day for it).
    edited June 2017
    Little experiement with Topaz.
    Morning Kung Fu Practice by tkdrobert
    thanks you for that and your insightful comments once more. Ah the image is all about suggestion, with something like this its best to let the viewer take away what they find for themselves. And that is usually related to their life experiences or knowledge or culture/myths.
    edited June 2017
    Ha ha thanks, can't get away with anything here! Yes the back leg is raised off the ground (because he has seen something bad and is stepping backwarsd) hence the shadow being weird. I debated long and hard whether to fix it but thought I could get away with it - that'll teach me!
    looking good especially the foreground faces and the chap on the lefts musculature.
    edited June 2017
    Envy from https://www.daz3d.com/7-deadly-sins-vanity-and-envy
    with Topaz Clean applied in postwork.
    960 x 1080 - 202K
    Post edited by Artini on
    Nice.  I really haven't tried doing reflections in any real big way.
