Thank's Linday for Satine!
2»
  • Rod Wise DriggoRod Wise Driggo Posts: 2,345
    @Martial: Nice. What do you use for that comic look or how much is postwork?
  • nelsonsmithnelsonsmith Posts: 1,337
    j cade said:
    Do folks want some morphs for the outfit? I personally think It would look silly fully buttoned up, but did want the shirt buttoned one more up (and a few other tweaks). As it is I love the outfit so much. The detailing on it is fantastic. Holds up to closeup rendering as well as anything I've ever bought. I mean there are modeled buttonholes :D There's texture detail on the inside of the placket
    Here's a not completely finished render with the shirt morphs. Sidenote, but does anyone have suggestions for a good tophat? I feel a deep and abiding need to render this outfit with a tophat.
    See a little Betty Davis in there.
  • MartialMartial Posts: 431
    I use Photoshop for compose the  page ( you can use other graphic soft)  and Topaz ajust plugin with some manual  ajustments ( the plugin can work without photoshop)
  • RiggswolfeRiggswolfe Posts: 916
    Odaa said:
    She looks good in Eldritch Seeker (originally a G2M outfit, possibly on sale this weekend), if you want a more conservative alternative to the Satine outfit.
    That looks really good. What process did you use to convert it to G3F? I figure maybe fit it to G3M, save, then fit it to her? Or did you go straight to her?
  • DareshiranuDareshiranu Posts: 338
    Has anyone tried using the genital textures? I've tried and failed. Both on the normal set and the NGS set (which is what the genital maps to as far as I can tell). It isn't really as clear as it should be and really it should have duplicates of every material IMO. In any case I try to apply them and no joy. I didn't need them ATM but I like to make certain everything works. I'm using the base figure for another character I'm working on and the spot renders look amazing.
    Hm, it is looking like the gen map that isn't the normal map is only NGS, which I don't have, so I get an error as it's looking for a file. Maybe there is a missing non-NGS gen preset?
    I do have NGS and I still can't get a genital texture. I'd be happy with one that worked, regardless of type honestly. I've used the non-NGS and it looks great. I hope that Lindsay fixes this issue. Do you think I should create a ticket? I would have thought something like this would show up in QA.
  • xyer0xyer0 Posts: 6,518
    @j cade Oui! Want morphs!
    https://www.daz3d.com/shadow-man-outfit-for-genesis-2-male-s
    https://www.daz3d.com/maman-brijit shown below
    843 x 1250 - 4M
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    Hm, if you haven't already yet, I'd say definitely create a ticket. If the NGS preset isn't working and you have it installed then that's definitely something wrong. Like I said, I don't have it, so I would expect an error. Not sure if the non-NGS preset was missing or just not included, I was just going to copy settings from the torso at some point since the maps all appear to be included. I guess I could open to a ticket to clarify whether there was meant to be another preset.
  • I had to pass on her. Without a standard gens texture it's a no go for me. I don't have NGS. :-(
  • sapatsapat Posts: 1,735
    I have NGS, but not her, and I don't want to buy her just to see the issue with the gens myself.  So I guess we're both out of luck billyben. frown
  • OdaaOdaa Posts: 1,548
    Thank you, @Riggwolfe! I just converted it directly to her. I have Wear Them All, so I don't know how well this method works without it, but in my experience you're better off converting a G2M clothing directly to G3F, or G2F directly to G3M, rather than trying to double convert.
