Adding to Cart…
Only thing that has to install to C is the DIM application itself. Everything else can go back on D: (I'm downloading and installing to G), and uninstalling is optional (though reccomended for reasons of being able to uninstall going forward.)
I know I was pretty against it earlier, but since a couple of viable workarounds were found that allows me to not have to rebuild my runtimes, I'm feeling better. :)
Is there a quick way to uninstall and reinstall?
What'd I miss?
I'll tell you what I did just as an example. I am keeping my D|S 3.1.2.32 with all my Gen 3 and Gen 4 stuff. Basically, that's everything that is installed to C:\DAZ\Studio\Content. Then I also kept my D|S Pro 4.5.1.56 but I unmapped all my existing directories, including my Content directory, My Library as well as my Poser directories. Instead, I mapped my new C:\User\Public..... path. Then, I exported the user data I had installed via the DIM up to that point which was only the Genesis Starter Essential files. Then I reset the dabase, thereby wiping out all content. I closed D|S 4.5, opened it again, and re-imported my user data. From here on, I plan to install about 10 different items each time and categorize anew as I go along and only concentrate on Gen5 content. I 'm sure i will installi the Gen3 & 4 content into the C:\User\Public path as it becomes available and eliminate the old D|S 3 at some point.
Installed and have it downloading to my USB external drive with no problem started at about 2:20 pm and have downloaded 1,558 files at just under 1 MB/s to 1.3 MB/s
What'd I miss?
No real quick way to uninstall, though the DIM installs quickly, and the batch feature is a significant plus. However, due to some legacy content issues (and lots of poorly organized freebies), I'm still planning to install manually.
For right now, I'm downloading (still have 300 to go, started at 11 local time last night). Then I'm installing to a dummy Content Library in small groups, organizing it as I need to using my Windows File Manager, merging with the correct target Content Library, and deleting everything but the DIM added .ini file in the dummy library. Lather rinse repeat.
I won't be able to un-install using the DIM, and installing updates will require paying attention so I know what needs to be cleaned up, but the DIM will let me know about updates as actual updates, and not just something I forgot to install.
Sounds like a great plan to me! I don't have DS 3 any more. It kind of went out the door when my last computer was stolen so I only have Daz 4.5 installed and about 1/2 of the original stuff. And with the mood I'm in tonight I'm find with leaving everything installed the way it is and just switch over to the new C:\User\Public...folder. I think I will create a new place for all of the non-Daz stuff though to help keep it straight. I don't think that will mess anything up or at least I hope not. Like you, I'm concentrating mainly on Gen5 stuff. I haven't used the other figures in a while. I haven't started Categorizing anything up to this point. I really need to though because I spend more time searching, trying to remember how it was installed then it takes to render a pic. LOL.
I sure wouldn't rely on this program at this point. The most recent thing I got a few days ago was the Urban Shabby Chic product
This SHOULD have
Boho Chic
Urban Fashion Trend
Urban Shabby Chic for V4
When I originally got the exe products, all were there. I just went to DIM and the only part of it that's showing is Boho Chic.
They have stated a few different times that all the products haven't been converted yet
Will there be filters to select models separately, like V4, M4, Genesis? I'm still a fan of managing models in separate runtimes. Seems to me that the current application filters (DAZStudio, Poser) don't work well. Found DS files with a pure Poser filtering.
It might be possible with advanced filtering. I looked at the on-line docs for it, but it was late, and I was tired, so I didn't follow all that well.
http://docs.daz3d.com/doku.php/public/software/install_manager/referenceguide/interface/filter_field/advanced_filtering
I'm going to go with by guess and by golly.
Yes, but I thought that what was said is that V4 items were all converted, and these are all for V4...
Having used the Install Manager for a while on a less-than-fast, less-than-perfectly-reliable connection, there are a couple of changes I'd like to see.
1. The ability to resume failed downloads, rather than starting from scratch.
2. The ability to add files (such as failed downloads) to the start of the download queue, rather than only being able to put them at the end. Alternatively, the ability to designate some files in the queue as high-priority.
Sever stress test info:
During the afternoon DIM download speed was up at 4-5MB/s
In the last 2 hours it dropped down to 250-350 kb/s
Seems the next batch of e-mails went out...
Welcome to DIM ;-)
I've been fairly consistently at 1.3 MB/s since I started last night. I don't know what it was doing at 3 in the morning, obviously... :)
At release we did not allow for an alternative installation path for the application because of a problem with allowing it on the Mac. We are, and have been, looking at ways to address this.
So does this mean that I can not use the Install Manager properly yet? I am running on MAC and have all of my content (Studio/My Library) on external drive. Based on all the documentation I have read, it appears that you need to install everything to a Shared folder on C. This is really not ideal for me. Furthermore, what happens to all of my 3rd party installs residing in Runtime folder?
Thanks.
I'm really dismayed that another new DAZ product has so many questions and problems associated with it. I only read the first 10 pages in the thread - but come on! Stop innovating already. It's too much to keep up with. It's information/problem overload. I don't want to go through this any more. 500 questions, 500 problems, 500 fixes. When it works without problems for everyone, let me know.
I imagine the DIM was written in C++. I haven't done anything in that since 1991, but I do know there is a library that has functions to determine what OS we're running on. From there, it's a simple If...Else. If Mac, restrict install drive, else offer a list of available drives for installation. This should not have been an after thought, if it was known going in that Mac had restrictions.
Dana
The program installs to your system drive. At the moment there is no way to change this. You shouldn't have problems using the program the way it is. (The installer was designed to conform to Mac requirements, according to Spooky's post.)
The content is set to install on the system drive by default. This is easy to change. You can also very easily install to a new folder and arrange content whatever way you see fit, just like you would arrange freebies and products from other sites.
Nothing happens to any of your existing content unless it's DAZ content that gets updated by a new install.
You can install your content anywhere you want.
You should read further.
Coldrake
The questions are due mostly to people being reactionary and not being willing to try something before getting upset about it. Those who are using the software and are willing to look at really simple options are not having significant problems. It's not for everybody, but it's definitely pretty awesome for most of us.
It's so much easier to use than almost any graphic program this side of MS Paint...but will remain an enigma to those who don't try it.
Can you elaborate on this?
I watched a YouTube video on how to set the install path and read through the doc and it appears that I need to install everything in this shared folder and create links within DAZ. So does that mean I can only have DAZ original content installed in one place but then have my existing content and third party stuff still sitting out on my external drive? Should I be uninstalling all my previous content from the old location first then?
Have seen mine drop all the way down 119 kb/s then go up to 300 kb/s
It 's fluctuating up and down in this range
Earlier I was at 1.3 MB/s
Well that is what the DIM would like you to do - if the mac version is the same in functionality as the Windows animal you can choose where to install the files after downloading.
As for your other content - well it's not DAZ so we are left out in the cold there and left up to our own devices on what happens with said content
Spooky said they had gotten most things going back to V4. He didn't really specify "all V4 items," but rather used the original V4 as a reference point.
I've been distracted by real life lately and that product name doesn't sound familiar. Is it particularly new? It's possible the item came near or right after the top of their working list and thus the team hasn't gotten back to it yet while they dig back through old items.
Gemini: I'm serious when I say how easy this thing is. Easy to install, easy to try. I didn't browse any of the videos, just downloaded and opened. Most of it is very straight-forward. The settings for download and installation locations are under the Download Filters button.
You can install your content to a new location by clicking the "Install To Where" button in the Ready to install tab.
Coldrake
Can't recall when it came out. I just needed something to spend my PC coupon. on at the end of the month and it was on sale.
I just logged in to download my latest purchases (no point in downloading them from the site when I'll just have to do it over again) and there were several older products (though post V4) that showed up in addition to the four products I'd just bought. (Including, amusingly enough, the Morphing Python which I didn't buy today because I already had him.)
So odds are the missing products are part of the backlog. (I have them too, and they're not showing up on my DIM either.)
In my defense, the source of my freak-out was the idea that I'd have to re-build my runtimes to take advantage of the DIM, and the difficulties I had getting a clear answer to that. But I will admit that I over-reacted.
I don't think it's as great as the hype, but I don't think it's a waste of computer space either.
Is there a way to figure out what version of the product you have any more? I see nothing that tells you this information that was part of the product name in the exes.
Unfortunately, no. All of the Zips are "up to date" but whether that means the version you already have or not, the only way to find that is to reset the product through the store (the Store won't switch to zips for a while, apparently) or else find where someone has complied it.
I haven't tested, but I'm going to guess that resetting in the store doesn't reset it for the DIM.
Thanks for the answer - seems like a bit of a big oversight
