Some Questions to "Wear them all"
AD_639100AD_639100 Posts: 396
edited April 2017 in Daz Studio Discussion
Thanks for such a great tool, which is really very helpful and works very well. Only I have 2 very special problems with it.
Here my questions (and I hope someone can help me), what am I doing wrong?
1)
I use Bijin Jigoku from A3 to the Gn3F (the Matposen of the Dresses, Panty etc. I have applied before the Fit, since they do not function after the Fit on Gn3F), otherwise ok.
However, the dress handles, which can be placed over the matposes also invisible. I did this (before the Fit on Gn3F), but this shutdown of the fit is not considered. If you try to switch off this handle in the content library, then some of the dress will also be invisible - how can you turn off the handles without turning the dress invisible?
2)
I use Kishka Hair from A3 on the Gn3F (the maposen and the preset of the hair I used before the conversion from prop to Figure because the presets and the Matposen as a figure no longer function?)
Then I changed the hair from prop to figure and then fit on the Gn3F. Before the fit on the Gn3F everything looks ok, after the fit on the Gn3F (it doesn't matter if I take short or long hair), the Kishka hair has slipped upward and is only after some effort to adjust to the head of Gn3F. So I can indeed adjust the hair front right, but at the back og Gn3F's Head is without hair. I can not scale the hair, because the sliders after the fit doesn't work properly and doesn't show any effect on the hair. What can I do to make the hair fit properly to the head or to fit it after the fit?
I have attached a few screens, if my English translation is not understandable.
Perhaps somebody can help with my questions?
Post edited by AD_639100 on
  • AD_639100AD_639100 Posts: 396
    Nobody any idea?
  • LlynaraLlynara Posts: 4,772
    edited April 2017
    AD,
    1.) Sometimes there are dress handles that can be turned off under the dress itself, but if you can't turn them off without turning off the outfit, look at the Surfaces tab. There will be a surface called "handles". Change the opacity (or cutout opacity) to 0 and they should disappear. I have found this on a couple of different Generation 3 items, including the V3 Cheongsam dress:
    2.) If fitting the hair is not working, try putting figure into T pose, then positioning hair the way you want it and then parenting to head. The hair should follow the figure in poses but not drop down or look strange. I often do this with hairs that are not designed for the figure I'm using it on. Sometimes I use G3F hair on V3, like in this picture. Hair is parented, not fitted. Works best if figure starts in T-pose, since hair starts in T-pose too. (Both Gen 3 figures here have parented hair.)
    1143 x 535 - 82K
    Post edited by Llynara on
    Thank you for your answers. I shall try your tips.
