Dale by Saiyaness
124»
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,555
    edited April 2017
    been working on a very long render had several attempts at plus it is an actual long render and I noticed in this screen grab Dale kinda looks like reminds me of Daryl Dixon The Walking Dead probably with a little morphing could make him look even more soImage may contain: 4 people
    Post edited by Chohole on
  • SaiyanessSaiyaness Posts: 715
    barbult said:
    Saiyaness said:
    Rightyo, I'll get on it. From a quick test with different light set-ups, it's the spec maps making them super bright - they blend in properly with different spec maps (from a hairless chest) so no blinding white hairs.
    I don't draw on chest hairs. That would be silly. They're from the references.
    In future, I'll try to avoid body hair, full stop, so this doesn't happen.
    Will update here when I do the fix, okay?
    Oh, and I'll do bigger renders for you.
    Great! That is the kind of PA attention that creates loyal customers!
    Ok. Abel is a tricky one to fix. I tried a few things and it's a tedious task removing all those white hairs. I also tried inverting the white hairs, per hair, on the spec map and that made me want to kill myself. :p
    A quick fix for you now, worked for me, was to raise the Glossy Roughness and lower the Top Coat Weight, but I daresay it'll depend on lighting.
    At the end of the day, if these are recent purchases, you can always get them refunded. If you bought Abel a while ago, send me a private message and we'll work something out.
    In the meantime, Dale will definitely get an update. Abel, I'll see what I can do...
  • no you can't have them back Saiyaness they're mine now and they're staying in my runtime don't want to upset my ladies
  • barbultbarbult Posts: 26,176
    edited April 2017
    No, I don't want to return them either. The white lines are only a minor annoyance for the most part. I render more clothed characters than bare chested ones. I messed around with Abel and used the Photoshop healing brush on the texture maps, and that helped a lot. It [my Photoshop edit] is not the level of work you would sell, but it is OK for my personal use. I will also try your surface settings suggestions, because Abel's chest looks very shiny. I'm sure lighting has a big impact on it. I was just using an HDRI that I use all the time, no bright photometric lights or anything like that on the Abel renders.
    If you can fix Dale, that will be good enough to satisfy me. Thanks.
    Post edited by barbult on
    edited April 2017
    Here is Abel after my Photoshop edits and your suggested surface changes. It is good enough for my use.
    1600 x 2000 - 2M
    edited April 2017
    Back to Dale...
    Here is Dale doing construction. This is pure Dale with nothing else mixed in.
    1600 x 2000 - 2M
  • MelanieLMelanieL Posts: 7,716
    edited April 2017
    I'm loving Dale so far, although I agree that those long white hairs stand out a bit. (So thanks for the news of an update in the works).
    Here I was just trying both my latest purchases.
    768 x 1024 - 611K
    Post edited by MelanieL on
    Dale is definitely getting an update. I can't erase (well) the white hairs mixed in to his chest hair but those errant ones are fine. The same tricks with Abel might work. (Those pesky spec maps - I'll tackle that problem during production next time so it's not a problem later :p). I'll probably just Frankenstein a bare chest in. I've done it before. :p Thank you for being so understanding. I feel like Abel would require a whole new chest to fix his hairs. I'll just do better next time. :)
    He looks very nice, MelanieL.
  • nonesuch00nonesuch00 Posts: 18,714
    I won't be returning, even without the update.
  • mrposermrposer Posts: 1,134
    edited April 2017
    Here is a render of Dale wearing Elven Leather Tunic from Xurge3D and Wezor Hair from Emma and Jordi here at DAZ.
    1200 x 1000 - 580K
    Post edited by mrposer on
    Ok, fix has been submitted to Daz. I'll let you know when it's live.
    Here's a render.
    The first is just the fix, no material changes.
    The second render I changed the following material settings because the specular was a little high in the previous render. It also lessens the white hair effect (and fake hair bump) look in general having a smoother surface.
    Glossy Layered Weight 0.50 (from 1.00)
    Bump 1.00 (from 1.50)
    And I probably raised Glossy Roughness and Top Coat Roughness to 0.70 but I can't check because I closed Daz Studio. :p Whoops!
    Again, everything depends on lighting.
    Okay, back to work now. :p
    2000 x 1600 - 1M
    2000 x 1600 - 1M
    edited April 2017
    Dale and Abel work construction.
    1600 x 2000 - 2M
    Thank you, barbult - I'm liking your construction men too, doesn't Abel look different with that full head of dark hair?! (And that's some tattoo as well)
    Thanks, MelanieL. Hair makes quite a difference, you are right. The tattoos are from Inked Vol 12. The tattoos have several issues which make them less than perfect. They started out with bad seam lines, which the vendor improved with an update. They only work on G3M Base UV (not any of the Daz Original characters, like Lee, Gianni, etc.) They have no gens material and don't blend with that area at all, so tattooed nudes are out. There is a whole discussion over in Novica's thread.
    I like your construction dudes, Barbult! Nicely done.
    Thanks, Serene Night.
    I see an update for Dale in the DIM, but I use Daz connect and there is no update there. sad @Saiyaness, it you are still following this thread, can you ask Daz why the update for Dale was not made available in Daz Connect, please?
  • deathbycanondeathbycanon Posts: 1,227
    edited April 2017
    I'm posting this here because I posted this on facebook and even another 3D artist had to ask if the hands were a photo or a render. As soon as I got this idea I knew I wanted to use Dale because the skin has so much detail and I needed that for this close up. So this doesn't show all of Dale, but it really gives you a great example of how much detail went into every part of this character. Thanks for the great work @Salyaness
    1000 x 759 - 359K
    Post edited by deathbycanon on
  • msam921msam921 Posts: 141
    This render is so well done. Great use of Dale!
  • cherpenbeckcherpenbeck Posts: 1,416
    I love that! Thanks for showing us! And as for Dale,I'll keep him even without any update, he's just great.
  • Dale is awesome....and the texture is fantastic.  Awesome image deathbycanon !
  • Playing a bit with wear them all expansion.  The M3 casablanca suit on Dale in a render studio setup.
    casablanca
    I loved that render when I saw it in another thread - and I wondered whose hands they were too. Thanks for the information, I shall have to go and scrutinize my Dale's hands to see if I can get them looking so real
    edited May 2017
    Dale on a Date
    2000 x 1500 - 1M
    edited July 2017
    I made Dale into a toon the other day.
    1600 x 2000 - 1M
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    He makes a great toon!  Who would'a thunk?
