LineRender9000 [Commercial]
1…4567810»
  • FirePro9FirePro9 Posts: 456
    Being able to assign unique colorid to all selected objects and/or to all selected surfaces in a secen would be most useful.  Thanks for continuing to tinker with this!
  • djigneodjigneo Posts: 283
    Sure thing. This always was a project to support my artwork and getting back into the art brings up little things I want to improve.
    For any of you wanting to try out the ColorId assignment scripts, send me a note. I'm not sure when I'll get the other features completed for the "official" update as of yet. Real life (and full time job) time constraint sort of things.
  • Oso3DOso3D Posts: 15,127
    That's pretty much the origin of my WTP shaders. ;)
    'I could really use something that does X, but nobody's stuff does X. Better do it myself, I guess'
    One of the upsides of this product:
    PWToon, and several other similar things, fail to outline the boundary between opaque and transparent portions of clothing. Like, say, dresses where dress length is handled by cutting parts of the dress out via transparency.
    LR9K's colorID outlining, on the other hand, handles these elements properly.
  • AnEye4ArtAnEye4Art Posts: 875
    I just bought linerender9000 and need any good tutorials on how to get good line renders like in the photo. This software should have came with at least a video tutorial.
    960 x 1248 - 296K
  • pavsikakyjpavsikakyj Posts: 139
    Awesome product. Thank you.
    1280 x 720 - 1M
    Check the faq, it has several explanations & links to user-created documents as well.
    I appreciate that. Nice render!
  • vrba79vrba79 Posts: 1,548
    Is there an option that just renders everything as one pic, or do you have to render the outlines seperately, and then assemble them in photoshop?
    edited June 2019
    LR9K is very versatile, in a single setup screen you select which cameras and render engines you want to create the various and multiple images AND in the composite section you identify which of those images you want to combine into a single image.  So yes you need to first render outlines but then LR9K combines them into a single composite image, therefore, no need for Photoshop. You can also use previous render images in your composite image so it can act like a separate compositing app.
    3453 x 2078 - 550K
    Post edited by FirePro9 on
  • EightiesIsEnoughEightiesIsEnough Posts: 1,271
    edited August 2019
    So, I am wondernig, how do I get clear black Fresnel outlines in the hair, clothes and body?  The outline surrounding the figure does work no problem, but I am hoping to allow for clear Fresnel outlines within the figure.  Every time I applied the Fresnel outlines, the renders came out horrible.
    I read just now, in another post in this thread ,something about Line Output, and I am wondering how to make the Fresnel and lines clear enough to look appealing?
    I feel as if pwToon, while it is good, may be nothing compared to LineRender9000.  I have to find out how to use the line output function.
    Post edited by EightiesIsEnough on
    edited August 2019
    Artini said:
    Line output could be probably used for coloring books making.
    I was trying to explain yesterday, but nobody responded.  What settings would I have to use in order to get a result ike this in line output, as shown in the quoted graphic?  And if I were to use barefoot characters, what settigs would I have to use in order to have no blurring between toes?
    JonSea31 said:
    Check the faq, specificially the question "What settings do you use in your cel-shaded style?" There I detail the settings I used in the promo images along with a few other tidbits. Hopefully that gets you close. Honestly getting good Fresnel lines takes a bit of play with Line threshhold and Line width, in my experience.
  • Hello everyone.
    I encountered some issue with LR9K. I had to reinstall the system on my PC. And after that I can't get outlines renders. LR9K generates only source files like the one I’ve attached. I also get this message in render process window:
    3Delight message #143 (Severity 2): D2004: failed to open display driver 'C:/Program Files/DAZ 3D/DAZStudio4/displays/png.dpy' (display driver returned '4')
    Can anyone help?
    1600 x 900 - 619K
  • Come on, kind people. I reinstalled videodrivers for 5 times and Windows for 2 times. Tried 4.10 and 4.12 DAZ versions. Now It doesn't even save the source files. I don't know, what to do.
    edited October 2019
    I've definitely encountered this error before but I'm not yet remembering everything about it. Do other display drivers work? TIF for example? I'm wondering if it's isolated to the PNG driver.
    Edit: It occurs when the filepath for the output file (image file to save after rendering is complete) is invalid. 3Delight will complain that the display driver doesn't know how to write the file.
    Post edited by djigneo on
    edited October 2019
    Hi! The same happens with TIF format too ((.
    Post edited by pavsikakyj on
    edited October 2019
    For those, who can catch the same problem I will give the solution om the issue, wrote in upper post.
    The destination folder for your LR9K renders mustn't contain non-Engish letters or characters.
    Once again I want to thank djigneo for the great product and support. You are awesome.
    edited April 2020
    Hi again! I encountered some problems with LineRender9000 lately. For now I use only Edge blend for my purposes. Then compose it myself.  Every time I launch the script, it crash the DAZ when the rendering is done. It isn't the critical issue but sometimes it bugs me. But lately the script began to crash right after the begining of render. Only on some scenes. I noticed that when I don't use Color ID the render doesn't crash until the end and I get the outline picture. But in this case render takes 20-30 times longer time. That's a real waste of time. I can't afford (((.
    ________________________
    In case the render is broken before the image is ready the error is:
    Exceprion Reason:
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtScript4.dll" at 0033:000000008C7EE1BC, QScriptEngine::signalHandlerException()+18380 byte(s)
    Log:
    2020-04-22 09:04:22.141 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-04-22 09:05:48.043 Loading script: E:/My DAZ Library/Scripts/LineRender9000/LR9K AutoRender.dsa
    2020-04-22 09:05:53.229 WARNING: Script Error: Line 277
    2020-04-22 09:05:53.229 WARNING: TypeError: Result of expression 'diffuseProp.getColorValue' [undefined] is not a function.
    2020-04-22 09:05:53.229 WARNING: Stack Trace:
    <anonymous>()@support/djigneo/ScriptedRenderer/LineRender9000/OutlineGlobals.dsa:277
    2020-04-22 09:05:53.236 WARNING: Error executing definition file in DzScriptedRenderer::setDefinitionFile().
    2020-04-22 09:05:53.699 Ran tdlmake on image C:/Program Files/DAZ 3D/DAZStudio4/shaders/iray/resources/DTHDR-RuinsB-500.hdr
    2020-04-22 09:05:53.736 Rendering image
    2020-04-22 09:05:53.801 WARNING: Script Error: Line 277
    2020-04-22 09:05:53.801 WARNING: TypeError: Result of expression 'diffuseProp.getColorValue' [undefined] is not a function.
    2020-04-22 09:05:53.801 WARNING: Stack Trace:
    2020-04-22 09:05:53.807 WARNING: Error executing render script C:/Program Files/DAZ 3D/DAZStudio4/scripts/support/djigneo/ScriptedRenderer/LineRender9000/OutlineRenderScript.dsa:
    2020-04-22 09:05:53.808 Error executing render script.
    2020-04-22 09:05:53.888 Saved image: C:\Users\Administrator\Desktop\LR9k\11_01_Edge blend.png
    2020-04-22 09:05:53.889 Finished Rendering
    _____________________________
    When the render is finished, DAZ crashes with:
    Exceprion Reason:
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtScript4.dll" at 0033:000000008CF9E1BC, QScriptEngine::signalHandlerException()+18380 byte(s)
    Log:
    020-04-22 09:16:47.094 Loading script: E:/My DAZ Library/Scripts/LineRender9000/LR9K AutoRender.dsa
    2020-04-22 09:17:26.886 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-04-22 09:19:02.171 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-04-22 09:20:51.882 Ran tdlmake on image C:/Program Files/DAZ 3D/DAZStudio4/shaders/iray/resources/DTHDR-RuinsB-500.hdr
    2020-04-22 09:20:51.914 Rendering image
    2020-04-22 09:20:54.956 Created RenderCacheBlock
    2020-04-22 09:20:54.989 Created RenderCacheBlock
    2020-04-22 09:20:55.000 Created RenderCacheBlock
    2020-04-22 09:20:55.001 Created RenderCacheBlock
    2020-04-22 09:20:55.008 Created RenderCacheBlock
    2020-04-22 09:20:55.010 Created RenderCacheBlock
    2020-04-22 09:20:55.019 Created RenderCacheBlock
    2020-04-22 09:20:55.027 Created RenderCacheBlock
    2020-04-22 09:20:55.029 Created RenderCacheBlock
    2020-04-22 09:20:55.031 Created RenderCacheBlock
    2020-04-22 09:20:55.038 Created RenderCacheBlock
    2020-04-22 09:20:55.048 Created RenderCacheBlock
    2020-04-22 09:20:55.051 Created RenderCacheBlock
    2020-04-22 09:20:55.052 Created RenderCacheBlock
    2020-04-22 09:20:55.057 Created RenderCacheBlock
    2020-04-22 09:20:55.062 Created RenderCacheBlock
    2020-04-22 09:20:55.068 Created RenderCacheBlock
    2020-04-22 09:20:55.069 Created RenderCacheBlock
    2020-04-22 09:21:03.071 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-04-22 09:21:25.599 DEBUG: LineRender9000 lines file 'C:/Users/Administrator/Desktop/LR9k/de18_01_Edge blend_lines.png' created.
    2020-04-22 09:21:26.214 Saved image: C:\Users\Administrator\Desktop\LR9k\de18_01_Edge blend.png
    2020-04-22 09:21:26.215 Finished Rendering
    2020-04-22 09:21:26.215 Total Rendering Time: 34.59 seconds
    2020-04-22 09:21:26.303 Script executed successfully: E:/My DAZ Library/Scripts/LineRender9000/LR9K AutoRender.dsa
    But the product is stil awesome!
    1600 x 900 - 271K
    edited April 2020
    Investigating, thank you. I think this might be my first bug...
    Edit: It's caused by conditions where a surface material has a property named "Diffuse Color" but that property is not a Color property. Fix is being tested.
    Started to watch the new tutorial videos and learning some good tricks.
    FYI: Session 2 about doing line art for People does not install properly, tried both DIM and Manual.  I submitted a ticket.
    Looking forward to watching Session 2.  Thanks for these tuts!
  • mindsongmindsong Posts: 1,790
    FWIW, a couple of us submitted bug reports to DAZ and the full file-set was pushed out a few days later. I believe we're all back on track now.
    Watching the master work w/ his tool - as he described the paradigm and workflow approach to its use for specific effects was very very en'light'ening :)
    cheers,
    --ms
  • JoydivJoydiv Posts: 31
    edited May 2020
    (Deleted comment, no longer applicable.)
    Post edited by Joydiv on
  • DushkaDushka Posts: 17
    I'm really enjoying playing with this product. Once you get the hang of it, you can do almost anything. For anybody who wants to use Daz Studio to create and color your own cartoons, the ColorID feature does the flatting for you. It's brilliant.
    Here's an image I am playing with.
    1500 x 844 - 1M
  • pbaddhanpbaddhan Posts: 139
    Does anyone else have issues with the LR9K ColorID parameter not appearing in the shader tab?
    For example, I will load a scene and then set the render engine to scripted 3delight and then select LR9K for the render script.
    The LR9K ColorID parameter will not appear for some clothes in the scene, but will appear for props.
    edited May 2022
    It could be called something else and it can appear somewhere else as well, but still part of the shader/surface.
