Adding to Cart…
No problem...I just realised these are based on Uber not Shadermixer. I was obviously distracted due to all the talk about timtams...lol
Someday I'll turn you onto THIS:
http://www.niederegger.de/
Interesting...but not tim tams! lol
Double check the preset...it looks like it's loading with Translucency 'off'...
I just tried it, it's the Lamp Shade shader, I have opacity set at 95%... is it not loading properly?
I'll check again...
That's odd. Last night, it loaded with the Translucency value set, but the On/Off button set to 'Off'...now it's on.
Anyway, this isn't quite your settings...I had pretty much set this up before you put up yours, just kept playing with it, adding more stuff, because the scene just seemed to 'grow' on its own...
The shade has US on it. with Diffuse strength at 80%, no Ambient, Opacity at 100%, Translucency (using the same texture map as Diffuse) set to 20%. This one also had a Bump map that I switched to Displacement.
The 'main' lighting is my envlight2 shader and low intensity distant light as a shadow caster. The lamp is lit with a point light, set to roughly 'incandescent' (100W tungsten from here http://planetpixelemporium.com/tutorialpages/light.html) for a color value ..
Just popping back with a simple brick network for translucence and controllable shadowing. Most of the bricks you see are to make a screen combination mode (invert both inputs, multiply them and invert the result). In practice you'd probably feed the output connected to Colour on the base Surface brick into the Diffuse brick of a DAZ Material brick, and the out put feeding Opacity on the base into the Opacity of the DAZ Material brick, but as the render shows this does give greater transparency for shadowing than for viewing.
I'm wondering what sort of settings would be set up for different sort of shades. For example and opaque glass globe. Ideally a portion of the inside light would just pass through via translucence. But that does not really seem to work. Using a surface shader light doesn't really work either because then you don't have the other settings to give it the look of glass. And there really should be a light source inside to get the variable lighting that comes out the sides of the shade as apposed to the top of the glass.
Hmmm....that one requires some thought, but it probably would be easier to do using a geometry shell and the original shade with separate shaders on each, instead of trying to do it all with one shader on the shade.
That's what my network is doing, though it needs to be combined with a DAZ Material brick or other bricks to generate specularity and so on. Getting the effect of light being concentrated by passage through glass would need a caustics shader rather than regular lights, materials and cameras.
I copied your network earlier today Richard and I have tried having the default material in there. It seems to add the specularity but not reflection.
BTW.. why does DAZ crash every time I try and save a shader?
Reflection needs extra bricks - have you tried copying a surface with reflections into Shader Mixer as a starting point?
Not sure about the crashing - I din;t save my test scene to see how it went. Is it all SM scenes, or only some?
I've not tried saving them as a scene. Just tried to save the core shader so I could go back to it later if need be. So far about 4 have caused a crash. Including a copy of yours.
Is it saving the scene, a preset or the brick material?
When I save the shader as a file.
I'm hoping this is the same settup as Richard's... still looking for discrepancies...
Looks right, assuming you are subtracting the colours from white in the screen process.
Oh goodness... I could pretend that I understood what you just said... but I think I have to leave my pride at the door... I have not the first clue what I'm doing :)
Value for bricks 8, 6 and 3 should be white - they are closed, so I can't see what you have there. Then Value 2 is the colour you are wanting to invert, from the Diffuse or Translucent brick etc.
KEWLNESS! That's one of the errors... I never changed the value from Black!
Okay, so then, if I wanted to add a texture, I'd plug that into the diffuse colour brick, right? Same with texture to the Transluscency brick?
Translucence shouldn't need a map, unless you want to vary its strength (like an opacity map). If you are wanting a real material I would use a standard DAZ Material brick, then take the stuff that goes to colour on the right (with a map set for Diffuse, yes) into the Diffuse input on the DAZ Material brick and the stuff I have going to Opacity on the root brick going to Opacity on the DAZ Material.
translation stick a DAZ default material brick bettween Binary Operation (3) Brick and the Surface (1) brick connecting the output of the Binary Operation (3) to the diffuse input on the DAZ Default Material, and then connect the output diffuse from the Default Material to the input diffuse on the Surface (1) brick
do the same with the Opacity channel, outpput from the IfElse (4) brick to the DAZ Default Material brick, then from the default material brick to the Surface (1) brick.
Welcome to my world...thanks to everyone for posting info!
Haven't had chance to play yet. Hopefully before I go back to work next week.
