Caitlin for Genesis 3 Female(s) by addy. Seam visible between torso and leg textures. [FIXED]
AnotherUserNameAnotherUserName Posts: 2,727
edited April 2017 in The Commons
Hi Everyone,
I finally got Caitlin by addy, http://www.daz3d.com/caitlin-for-genesis-3-female-s , and I discovered seams between her torso and leg textures. The seams show on both the left and right outer thigh (see pic). Can someone else confirm this? Hopefully addy will see this. If not ill try messaging her.
Post edited by AnotherUserName on
«1
  • nicsttnicstt Posts: 11,715
    I have and there isn't; so check UVs are set correctly.
    double check to make sure that the surface setting is exactly the same for the two different areas
  • SkyewolfSkyewolf Posts: 486
    I had a problem like that when I applied a skin from one set and a normals from another....if there's a mismatch it causes a seam right there. There's no way a seam that obvious would've made it past testing. My guess would be the normals issue or, as Chohole said, surface setting issue.
    I've had em almost that bad, but granted not that bad
  • Sorry for the late reply... power has been off for the last couple hours. It dosent matter how I load the character, preset or morph then skin, she always comes out with seams in the legs. Ive checked all the surface settings and everything looks right...
    I have the character and I never noticed that...lol. Of course, that doesn't mean there ISN'T a problem. I frequently don't notice things ;).
    Laurie
    Laurie
    Yah I just dont get why no one else isnt having this issue (although I shouldnt be suprised frown). Laurie, your avatar is fantastic by the way!laugh
    Well, well....whadda ya know? It does it for me too. Loads that way. However, if I change the UVs from Vicky 7 to Base Female it disappears :).
    Laurie
    Can you please report this as a bug         thank you
  • Reporting now. Thanks for confirming Laurie.
  • Reported.
    Quick, get the Raid (or whatever the equivalent is where you live).
    No problem :)
    Laurie
  • Confirmed by tech support.
  • 3-D Arena3-D Arena Posts: 199
    That could also be a gamma setting issue in either the specular or diffuse maps.  I've ahd that happen where the gamma setting for specular maps is set at 0 for some maps and at 1 for others, causing that difference.
  • GallCommTVGallCommTV Posts: 239
    Yep! You're right Chohole, ... that's definately a bug!
    Laurie
    The character loads (called Victoria 7) but uses default (G3F) UVs. Even if I change the UVs to v7, still no seem.
    I use 4.9.3.166 Beta.
    It would affect all the texture, not just a small section. Or at least, the many times I've had to change it, it has.
    Newspaper first, then something like Raid.
  • nicstt said:
    Laurie
    So, nicstt, your still not seeing this? I noticed that your on the beta, do you still have 4.8 running as well? Could you check her on that?
    edited March 2017
    nicstt said:
    Laurie
    I did and not seeing there either.
    EDIT:
    As you can see, no seams; loads stating V7, but uses Default UVs.
    And I rendered too, to be sure; no seams.
    1121 x 774 - 99K
    Post edited by nicstt on
    Mine loads with V7 UVs. o.O....Strange. Was there an update??
    Laurie
    Laurie
    Not sure. But if nicstt is loading correct across two versions, maybe this is an issue with daz?
    edited March 2017
    Well, as soon as my render is finished I'll have to try some things. In order to see if I was getting the split seam too, I loaded full character from the character folder. It loaded with V7 uvs and with the seam showing. I changed the uvs to Base Female and poof....it was gone. I think I need to try adding her texture to a vanilla G3F then add the morph and see if that's different.
    Laurie
    Post edited by AllenArt on
  • Well, I already tried the morph on a straight g3f and then applied the skin. I got the same seams.
    As you can seen, it's a year since I bought the character. There have been no updates as I recall, and none are showing.
    343 x 245 - 43K
  • Richard HaseltineRichard Haseltine Posts: 111,852
    and which UV set is being used after applying the skin? Morphs have nothing to do with textures.
    She loads with a v7 uv.
    edited March 2017
    Which, by what others have said, is not correct - do the seams go away if you set that to the default UV set? If so that would still be a bug, and I would recommend saving a fresh set of Materials presets for the combos you use pending a fix, but at least it would have a simple work-around.
    Mine loads with a V7 uv also. The seam does go away if I switch to base female uvs. I can work around it ;).
    Laurie
  • According to tech support, this has been fixed. Havent tried it out yet.
