Poser Companion File Error
mathmanmathman Posts: 0
Hi,
Why am I getting this error when trying to create a Poser Companion File from a duf file ?
Any help appreciated.
thanks,
Andrew
    Do you have SR3 for your P9/Poser Pro? This was the cause of the error in my case.
  • mathmanmathman Posts: 0
    Yes, and its worth noting that I was able to successfully create a PCF for a Material preset.
    Thanks.
    Have you double-checked your versions of DSON, the companion files and the core? Version mismatch can also cause this error.
    I don't know how to check the version of DSON, the companion files and the core. Can you please tell me how I can do this ?
  • Richard HaseltineRichard Haseltine Posts: 111,922
    The installer names have the version.
    The version numbers are:
    DSON : 1.0.0.13
    DAZ Studio : 4.5.1.6 Pro
    Poser : 9.0.3.23027
    Does this tell you anything ?
    Hello ?
  • KeryaKerya Posts: 10,943
    I have exactly the same versions ... I am adding a screenshot of my settings.
    (as I don't use metadata, I don't rely on them for getting the correct library and extension)
    472 x 534 - 63K
    Did that help?
    To be honest, I haven't tried it.
    I have been working on numerous other problems, and haven't got back to it. I will aim to let you know when I have some results.
    Thanks.
