So How Do I Fire Up "Look at my Hair" ??
mathmanmathman Posts: 0
Hi,
As the subject says. I cannot find the icon for LAMH anywhere in my DS4 interface. Furthermore, I cannot find a menu entry. .... and yes, I have installed it.
Any help appreciated.
regards,
Andrew
    edited January 2013
    There is a ninety odd page thread here in the Commons by the vendor : http://www.daz3d.com/forums/discussion/381/
    The information should be there I'm sure. Are you using DS 4.5?
    Post edited by JimmyC_2009 on
  • Richard HaseltineRichard Haseltine Posts: 111,896
    Should appear in the Create menu. If it doesn't, exactly which version of DS are you using - help>About DAZ Studio?
  • mathmanmathman Posts: 0
    edited January 2013
    LAMH : 1.0.0.0
    DAZ Studio : 4.5.1.6
    It does not appear in the Create menu. Neither does it appear in the Windows/Tabs sub-menu.
    Post edited by mathman on
  • adamr001adamr001 Posts: 1,322
    Did you install the 32 bit version on a 64bit DS install? Go to Help > About Installed Plugins and make certain you see the plugin there.
    No. I only have the 64-bit installer on my hard disk, and that is what I used. It does not appear in the list of installed plugins *sigh*
    I'll try and install it again.
    So I installed it again, and it asked me to uninstall the previous version - thus showing that it had already been installed. Now it appears in the list of installed plug-ins, go figure.
    The only thing that sill does not appear is the icon at the top of the DS window.
    You mean like all the other tool icons? There isn't one — using the Create menu is how LamH has been set up to work.
    Although... since the look of D|S can be customised pretty much any way you want, does anyone know how to set up a custom action for this plugin? I've never done it myself.
    edited January 2013
    I was watching one of the author's videos, and he started LAMH from an icon at the top of the DAZ Studio screen. That is where I got the notion that the icon should be there.
    I had a look at the workspace and the preferences, and I couldn't work out how to add the icon to the toolbar at the top.
    Go to Window > Workspace > Customize and you can add the LaMH icon to any of the main toolbars.
    I went to that dialog, there is a list of Actions a mile high. I went thru' all of what I thought might have been appropriate, but couldn't see anything that allows me to add new icons to my toolbar.
  • ColdrakeColdrake Posts: 236
    Hi Mathman, you'll find it under "Create". Just click and drag the LAMB icon to the toolbar of your choice.
    Your icon will look a little different, I made a custom icon so it will show up better.
    Coldrake
    616 x 65 - 18K
    616 x 724 - 75K
    Thanks, but that didn't work in that the icon did not appear in the toolbars at the top of my screen. I tried going out and back in, but that made no difference.
    What layout are you using ?
    Take 2, I got it after all.
    Thanks !
    Thanks !
    Excellent! Glad you got it working. I'm so used to using the same layout I sometimes forget there are others, I didn't think about things being in a different place. I use the Darkside Style customized to my workflow. I love that you can put pretty much anything in a toolbar. I have shaders, characters, cameras, whatever I use most frequently.
    Coldrake
    1919 x 1155 - 190K
    Incidentally, this is a critical question in D|S4 when there are problems like this — what you see, and sometimes what you can see, varies depending on which layout setting you use. E.g. the amazingly badly named "Full Service" layout, which many D|S beginners are presented with (with no easy way of knowing there are other options) is actually very limited and will not let you see many of the more advanced functions.
