List of Shader Mixer Tutorials and Recipes
2
  • PendraiaPendraia Posts: 3,614
    Give me a day or two: sure. I'll try to post some legible screenshots by the weekend (and put the shader itself up at ShareCG).
    That would be great!
    Thanks for that...
    Pen
  • BejaymacBejaymac Posts: 1,952
    Plug a Clamp and Step between your Displace-Standard & Weave bricks, connect the Weave's output to the Value connecter on the Clamp & Step, set min to 0.9 and max to 1, set operation to Smooth Step. That wont give you a diamond pattern but it will give you the same thing you have on that dress in the picture.
    PS I'm using DS3 SM brick names as I hate the SM in DS4, I spend more time fighting the bloody workspace than I do making shaders, I really would like to meet the idiot that designed it, so I can punch his ****in lights out for having nerfed it so bad.
    To get an actual diamond pattern you'd have to change the way it's calculated to begin with...
    Thanks for the info Bejaymac...that will come in useful!
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    edited December 2012
    Here's the shader tree, entire, at 31%. I've still got to annotate the rest of my screen stills (partial node trees, at 100% zoom) but will post them shortly.
    Some repositioning of nodes was required, but the recipe is intact.
    815 x 580 - 290K
    Post edited by Eustace Scrubb on
    This is the node walk-through. I got the color values more-or-less from Lakys' still-splendid Blue Steel shader (circa DS 1.8 or so). Except for the Root Value change, as noted, this is the shader I used on the deck-plate dress on page 2 of this thread. I'm still fine-tuning it but hope to have it on ShareCG by the weekend. Some nodes and values are relabeled, but hopefully recognizable: "Transform to Screen" is a standard Transform node, but it's set to transform to Camera.
    I'm splitting them into multiple posts to maintain sequence.
    810 x 537 - 300K
    Thanks for doing that...
    Here's the next portion: the node progress is Right to Left, because I started making procedural node shaders in the P6 material room. I tried to allow some overlap so that you can follow more easily.
    813 x 534 - 329K
    Half-way there: here we come to the end of the Displacement portion of the shader. Unlike most universal surface shaders, the Displacement and Surface node chains are inseparable.
    816 x 538 - 328K
    Here I bring down the Occlusion Node seen above, and show what it's used for.
    814 x 539 - 271K
    This shows all of the basic ingredients of my surface shader. The only node you have not seen is the Surface Root node. But as it is plugged into the DS Default Material node directly (Color to Surface Color, and Opacity to Surface Opacity) its inclusion would have been redundant. I opened up surface values that were changed from their defaults to show the new colors or values.
    812 x 534 - 366K
    Wow...that's very interesting. I will try and have a play in the next few days. Just finished setting up a second monitor so I'm busy seeing what I can do with two screens.
  • BWSmanBWSman Posts: 0
    Here's a recipe I came up with while trying to recreate the Poser mat file for Flesh Forge's Peligro swimsuit. I'm trying to get the mesh look that football (American Football) and basketball jerseys have. 1st image is the textured fabric. 2nd image is an untextured clase-up. last two images are the recipe.
    Note: the tile brick is connected to the displacement brick and the opacity channel of the Default material brick.
    1553 x 847 - 249K
    1556 x 837 - 311K
    800 x 600 - 467K
    800 x 600 - 319K
    Post edited by BWSman on
    Very interesting...another one for me to play with while I'm on holidays.
    Paul's (aka Flesh Forge) Darling Nighty, I used the Poser transmaps rather than the gray DS ones and DS3's SM, these test renders are nearly two years old so if I can find my DBM files I'll post a screen shot.
    494 x 660 - 284K
    494 x 660 - 137K
    Post edited by Bejaymac on
    Very nice...you seem to have gotten the transparencies working...I really struggle with that in SM.
    Struggle in what way?
    Getting the opacity to work by plugging in a map to the brick which has the standard surfaces...sorry computer isn't on and my brain is in holiday mode. It's the one that is plugged into the root surface brick.
    Whenever I've tried to use it as you would in the surfaces tab it hasn't reacted the way I've expected it would. Mind you it's a while since I initially tried and it may have been fixed since.
    You've lost me there Pen, for me opacity has worked the same way in the SM since the DS3 pre release betas, if the info into the opacity Color node is "black" then it's invisible, if it's "white" then it's solid, which is exactly the same way DS has always used it with every other shader.
    which is how it should work...at one point when I tried that it didn't work. It may have been a bug in the version i was using at the time. I will have another play and see if it is still an issue. Most likely it's been fixed.
    I've uploaded the Deck Plate shader, as promised.
    http://www.sharecg.com/v/66559/view/21/DAZ-Studio/Steel-Deck-Plate-material
    Here's my CMYK node set: It seems to work correctly for splitting out the relevant channels.
    1141 x 535 - 358K
  • Mage 13X13Mage 13X13 Posts: 453
    edited April 2013
    I've made a couple of them myself, but nothing even near as complex as this! What does it do when the shader is applied to a model? Perhaps a quick render of something you used it for, maybe?
    Post edited by Mage 13X13 on
    Thanks Eustace, that looks useful...you wouldn't by any chance be the person working with Lady LittleFox? That looks like it would be useful for doing some of what she does with her new product for Poser. She said she was working with some DS gurus...; )
    No--- not blessed to be a collaborator (unless it's someone else copying my putzing). I just translated the RGB - CMYK algorithm from this CodeProject page into a nodular equation. I found that via the WikiPedia article on the CMYK Color Model(which I'd bookmarked).
    It's (ostensibly) the procedural equivalent of
        Black   = minimum(1-Red,1-Green,1-Blue)
        Cyan    = (1-Red-Black)/(1-Black)
        Magenta = (1-Green-Black)/(1-Black)
        Yellow  = (1-Blue-Black)/(1-Black)
    and I figured the node tree would be useful to others as well.
    BTW: Has anyone else found ShaderMixer to be more finicky when custom nodes are left grouped? I always seem to get better results when I ungroup them (or I did with D|S-P 4.0, and carried the habit over to 4.5).
    I haven't used the grouping...sounds out of my league.
  • EximorphEximorph Posts: 35
    Two different eye colors in Shader Mixer
    This gets asked about in the forums occasionally, so I figured I would link this here before my post gets lost in the dark depths of the Commons.
    http://www.daz3d.com/forums/viewreply/321399/
  • IceEmpressIceEmpress Posts: 639
    ;_; None of those archived tutorials are of any use because the tuts are in the hotlinked images which are broken...
    THIS is why I prefer-- no, DEMAND 100% text tutorials on the DAZ forums.
    You'll get further if you ask nicely than if you demand....
    However if you follow the process listed below you can access the images. This was posted on the first page of the thread. I suggest you read the thread before posting in such a manner next time.
    Click on any link, then on the browser bar add "archive" after "forum" so that it reads "forumarchive.daz3d", this will display the thread. To view images copy the "postimages/origimage_whatever.jpg" part of a picture link and add it after forumarchive.daz3d.com/ on your browser bar
