Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Try clicking Download Filters and then checking Connect Installed - for some of us the main installer is being incorrectly flagged and won't show in DIM without that option (plus the usual ones which you must have to be seeing the beta) set.
And I use it all the time in my renders, well used, I can not now since it looks horrible.
I filed a ticket to tech support , I guess I hear after the weekend, was told it would be tested.
Sorry, can't find it. I can only find public builds or DSpro, which is a zip file labeled as 4.5.
I think what you're seeing is the general release. See the very top of the first official announcement post in this thread:
Daz 3D is pleased to announce Daz Studio 4.9.3 Pro General Release!
If that's not it then someone needs a kick up the bum.
(edit: just to be clear, I'm referring to what's in the Product Library. I know nothing of DIM)
Thank you. So this is the general release, but still labeled as public build?
Can't say about DIM, but my Product Library make no reference to "public build". It just lists (for example) "DAZStudio_4.9.3.166_Win64.exe"
Same version as announced at the top of the thread.
<beeeep> deleted O.K. : now I've got it. The installer still gives the public beta path, but yes it is the general release. The world is fine again. :-)
After fiddling around for a while I think I have figured out how to HIDE Vendor Categories, you have to use the Content Library > Categories and DELETE them there. As the documentation states, they are not DELETED, but rather marked as hidden. In this way you can move all of the items to the desired category of your choosing and then DELETE the Categories you no longer want to look at. So far this method is working fairly consistently for me.
Read the "Database Driven Content Views" section on the New Features page, here: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/new_features/start#daz_connect1
When the "Show Hidden Vendor Categorizations" preference is checked, all asset categorizations show up regardless of what you've modified because that is what checking the option so named, does. When the preference is unchecked and you remove an asset from a category (as defined by the vendor/store), that particular categorization is hidden (instead of deleted) in favor of whatever custom categorization you've defined.
One of the best iray engines so far , it is a beast on my system regarding real time rendering and rendering speed overall , I was waiting for months for that , so great start for 2017 ! I am back on the track !
My favorite : spectral rendering #1 , Cameras and lenses option ! especially Lens radial blur , Shutter blades etc.. and spherical VR camera .
Happy New Year Everyone !
Cath
Great to see you on the forums again. Glad to hear you're "back on the track."
Happy New Year to you, as well. Hugs.
-Anita
And the same for you! And looking foreward to more of your glorious tuts, as now I'm able to properly follow them (The Zbrush/GPU rendering)
*Throws flowers in general direction!
Awww sweet , thank you both ! I could not resist the new engine is a game changer al last for me , got inspired again :) see you around !
Guess it was too much to hope for the 3DL shadow instances bug to get fixed.
(If you use instances in 3DL and use High Resolution on the objects, none of the instances or original object cast shadows. Been like that for at least a year)
Also disappointed that the spherical camera, which is incredible, is also Iray only.
Is this new release still working with LAMH or it needs an update?
Yep.
Well, decided to try myself since I still have old daz studio installers to fall back on, so far LAMH seems to work just fine :D
Yes it was. Sorry, I was multi-tasking :)
Have the default resourse package and scene builder files changed? The files showing in my product library have the same names as the files I have previously downloaded.
Not lately no.
I noticed that previously saved Shapes are not working since I updated.
Genesis 3 will export at a higher mesh resolution than the usual 2498KB. Now its 2722KB even after restarting DS and PC.
And morph loader either stopped working or I'm doing something wrong because it doesnt save imported morphs. What is this Attenuate by feature?
Okay I deleted this update and reinstalled the older version. Now everything is working and the mesh is back to 2498KB and morph loader pro can finally save.
There are a lot of bugs with this update but Iray is better and faster than in previous versions. But sadly that doesnt help me with my work :/
I wonder if other content creators have the same issues I did.
This issue was confirmed by tech support and is now in bug tracker.
Turning off cms causes performance issue in ds.
I was just working with and manual export/import and Goz working just fine also, so the exported files are correct at 2.7 MB ,however you can't save the morphs , after exporting/saving the morphs and loading Genesis 3 there was no folders or morphs :( definitelly a bug
Attenuate by allows you to be selective about which part of a morph is loaded - there are numerous options if expand it and click the current setting, including using weight maps. As a result you can use, shape permitting, a single file for head and body moprhs or to create separate left and right morphs (the Morph Mirroring option can also help here).
I didn't have a G3F sahpe to test, but I had no trouble loading a G2F shape as a morph.
I was able to save the test shape I loaded above as a morph asset, and it reloaded, so the issue may be path or figure specific or depend on soem other option.
Ok found out what was going on , I did not noticed that the selected export folder for morphs (ASSET FOLDER ) was My Content Library , in place of My Library where I have my G3 , after I switched the folder in the export window and saved ,the morph loaded as well so everything is working fine !
so please dismiss my last post , no bug found :)
It not really matter here as my size of the file was 2.7 MB as well , but the poly count was the same so morphs loaded without issues , different export option may change the file size as more info/data is added to the obj with different options .
and all you need to pay attention to is poly count matching with the original base .
