Thanks Johnny,
Very helpful, did learn a lot I have been having some issues in trying to setup images, however I do have a question.
How do you set up images when the views are different sizes ?
For example I have a image of a plane, but the side view is smaller than the top view, I did play around for hours trying to work out how to get the side view the same size as the top.
Not sure if Gimp has the ruler option, but it probably has. I use PaintShop Pro, it has a Ruler option which is handy when trying to scale reference images.
What I normally do is copy all the references to one big image, set the rulers to a prominent features on the first image and scale the others using the ruler points.
Sorry I have not been here in a while, I did not receive a notification email that someone had posted in this thread.
John is correct about scaling the images.
I will be offline starting this fri. till late next week.
I will address this then.
Sorry I can not get to it till then.
Thanks a whole bunch!
Thanks Johnny,
how would I do this ?
thanks in advance
