Star Trek Builders Unite 2 "Renderings on the Edge of Forever"
1262729313250
  • mylochkamylochka Posts: 168
    MotoTsume said:
    Giving the other side a chance
    Niiiiiiice! I love the shine you're getting. Are your rendering in DAZ or Poser?
    (I should have a render of the M4 Cheron within the next half hour... if I can stop making up movie scripts about Garth of Izar...)
    Okay :-)
    The wall is 'temporary' as it will be replaced in the entire set but the doorway with forcefield itself is "done". So here's for those who wish to make use of it locking up those bad guys [and gals] [and monsters].
    http://www.mediafire.com/?guiumzxij3d2ltr TNG Brig Door
    And I even scaled it ... sized it for M4 and types.
    It loads in the centre so one can place it where they wish.
    Whole thing is uvmapped.
    Several shading domains.
    Force field has 2 layers and lots of mesh so theoretically one can morph in some field explosions and the like.
    600 x 600 - 249K
    600 x 600 - 228K
  • MotoTsumeMotoTsume Posts: 520
    edited December 2012
    I use Daz Studio 4.5 Pro - but to be honest the shine is a postwork trick LOL
    I run the render into Photoshop CS5,
    and one pass of Your poser action,
    then I add a background texture,
    then I use an action I have that give a soft edge glow, -it creates this on another layer so i then reduce that layers opacity down till i get the desired amount I like :),
    I then add signature and your frame action,
    size to the desired size as my render is normally very large
    and done
    NOTE: depending on picture other postwork might be done in between or after or before some of those steps
    Post edited by MotoTsume on
    thanks for the Brig door :)
    You're very welcome.
    Here's M4. Fixing a few problems with V4 then packing the whole thing up.
    669 x 669 - 251K
    and done
    Hmmm... that soft edge glow action sounds like it would be very useful...
    It is in a set I got some where , the set has a bunch of useful actions, trying to recall where i got it, it was a free set that I do know, might have been on deviantart
    will try to find the location
  • RedfernRedfern Posts: 1,647
    Mattymanx said:
    Is this a hint that you're converting Raul Manoru's Doomsday Machine from .MAX into a Poser/DAZ friendly format?
    Sincerely,
    Bill
  • TimbalesTimbales Posts: 2,424
    nice!
  • MattymanxMattymanx Posts: 6,997
    Sincerely,
    Bill
    I dont think the word "friendly" really describes the Doomsday Machine.
    and past tense... converted!
  • ThalekThalek Posts: 318
    In Star Trek: the Motionless Picture, the only parts I saw move on the space dock were some industrial lighting fixtures swinging out of the way before launch. I'm not even sure what the rest of the framework is supposed to be. Tool and parts storage? Worker break areas, offices, and life-support? Low power presser/tractor beams for manipulating large modules? Combinations of the above?
  • jaguarry3jaguarry3 Posts: 230
    Loving all the Cheron renders and couldn't resist doing one of my own
    1000 x 1029 - 328K
    Thalek said:
    In Star Trek: the Motionless Picture...
    Come now, they had a 45min fly-by of the new ship, so that counts as motion.
    I no longer have any episodes of Enterprise but I thought the sides moved out a bit when a ship was leaving or to accomidate a larger vessel. Its got arms that I can make move but its deciding if the rest is going to move or not.
    [bowing from the waist] Touche'!
    Hot d*mn! so, when might we see it available? I assume this will be one that will remain at Trek Meshes.
    Sincerely,
    Bill
  • Wolle1962Wolle1962 Posts: 0
    Downloaded this conference room from LBA in the Rendo Free Stuff section.
    http://www.renderosity.com/mod/freestuff/details.php?item_id=69964
    I saw the thumbnail, liked the design, and thought that I could use it for something Trek related. Soooo... Here's a conference room at Starfleet Command (Next Gen era).
    Good Idea
    Here is the Admirals Office:
    600 x 450 - 126K
    Sincerely,
    Bill
    It will be Trekmeshes only. I have emailed it to Erik and waiting for real life to slow down long enough for him to update his site with it.
    I will let you know when its available as he will email me back that its done.
    EDIT:
    Forgot to say, I have now reached the letter "E" in the list of ships for conversion. So having gone through them all, I have gathered all ships named Enterprise to be worked on. So you will be seeing a few more Enterprise models comming in the next while.
    Post edited by Mattymanx on
    Matty will make sure that we never forget the name . . . Enterprise.
    DOWNLOAD HERE: http://www.sharecg.com/v/66183/view/11/Poser/Cheron-Skin-for-M4-and-V4
    At last -- here is the completed skin texture for the ill-fated Cheron race. The mat files are a very simple version of the texture. A basic bump map is included in the version in the material room. Should work in both DAZ and Poser. I encourage you to experiment with adding sub-surface scattering. For Poser users, I recommend D3D's Perfect Skin python script (for sale here: http://www.renderosity.com/mod/bcs/d3d-perfect-skin-2---poser-python-script/71922) to enhance this and all my other skin textures.
    544 x 642 - 216K
    Did I mention that the Drydocks were up?
    900 x 900 - 472K
    This is an old lux render i did when i was still using ds3 and lux 1.2
    took about 5-6 hours if I recal to get to this stage - no postwork done on this except for signature borders
    opps lol wrong thread, danger of having more than one thread open LOL
    and thank for the Skins and also the drydock
    1388 x 1796 - 1M
    Starfleet Marine right?
    Oh, she's a real cutie! I never thought of the Cheron textures as being as stylish as it looks on V4... I suppose I've never seen the look played for glamor, though. Although quite accomplished as character actors, neither of the guest stars in "Let This Be Your Last Battlefield" was famous for his male model good looks...
    Forbidden Love like it says
    1500 x 864 - 233K
    Rage
    (can never seem to get ratty klingon hair to work right in DS)
    1500 x 864 - 259K
    was meant for a different thread but LOL could work as starfleet marines I suppose :)
    Aw, romance! ... or maybe dyslexia....
    This need no introduction.
    Comming soon to STMC. Close up included so you can stare for hours for no reason.
    Decals are removeable so you can rename the ship. StarFleet logo is removeable too so you can make it an ISS instead.
    900 x 900 - 439K
    900 x 900 - 382K
    Nice, cant wait :)
