Adding to Cart…
Hmmm, not tried that one, don't even know if I have that prop.
Don't bother...it's going to take a lot of work to convert it.
I redownloaded it and it worked, so it was something screwed up in the file causing the crash...but it would initially load, so what it could have been, I haven't got a clue.
But they are scaled all over the place, have all sorts of translations and such. So, after running it through and converting it, no matter what you do, once you try to fit it to Genesis, it does wild and unusual things. Basically, to get it to work is going to mean realigning every thing on the geometry, first, And since, I'd be doing all that, I may as well get it fit Genesis, natively and finish the process of rebuilding it as a native Genesis piece, anyway, instead of converting it...and that seems to much bother for a free hair that I may use once or twice. Plus I'm not even sure I want to use it for this particular project anyway...
So, scaling and parenting are going to have to do...
OK.. I won't bother then. I'm at work right now so don't have any of my runtime with me to check to see if I do have that hair. Is it sold here at DAZ? Can you provide a link for me to go have a look? If I do have it I might not be able to leave well enough alone and try my hand at it! :lol:
It's a freebie on ShareCG and Rendo...Mareek/Mark003.
http://www.renderosity.com/mod/freestuff/index.php?user_id=657797
Real pain in the posterior to convert.
OK.. home from work. Well this person def has some good little hair props. I downloaded the Gaga one... since i'm one of her little Monsters.. lol Came over beautifully with all morphs.
Here is what I do when I'm not sure if a prop is made for a figure... I DON'T assign it to one..
1) make sure the hair is parented to the head before you convert it to a figure
2) convert using the Transfer Utility but DO NOT choose a clone, just leave it at default.
3) Do NOT check off any extra boxes except for adding a smoothing modifier, the rest leave at default.
4) Choose your hair type, short or long so it's auto conformed to Genesis.
Convert... should work.
Simple Hair converted just fine. Follow my tips and you should be good to go. The morphs on this hair prop are not very well executed though. They totally need reworking. The Gaga hair performs better. The long morph just goes out forward and the others are kind of ... just OK... and others are a total miss for me.
Hi, can you please rewrite these tutorials in pdf form (forum difficult reading) and use more pictures to explain all this stuff.
it's difficult to understand, without pictures.
is this possible for you to do?
i really hope you can
thank you.
oops double post
I'm sorry, but I just don't have the time right now... Just copy and paste the info into a text file and take your time going over it. Once you do it once you will find is easier each time.
RAMWolf thanks so much for your Daz Zbrush tutorial. It really helped.
One thing I still can't work out is how do I get a Genesis or its clothing to load in Zbrush with its textures on. I would like to reshape the character and do some 3D paint directly using polypaint.
GoZ seems to have "update material" or UV options, so why doesn't it automatically export a clothed Genesis with their corresponding materials/textures? What is my option? Thanks.
Ah, well that's a whole different area I'm afraid. It would be nice if DAZ would update the GoZ to give options to export with materials but that's not the case.
Here's a link to another tutorial I wrote: http://www.daz3d.com/forums/discussion/6841/P105/#163761 Scroll down a couple more because the forums are a mess and don't lock onto the exact post as they are supposed to. It's post #111. It's a long read but it's worth it.
Raaaam I just wanted to say <3 <3 on the hair conversions! After work last night I spent around three hours going through my libraries doing all of this, copying over to materials folders, etc. DS4.5 is SO much better at it, so major kudos to the code monkeys and their brethren for giving us this lovely, lovely functionality and to you for writing up a procedure for it.</p>
I tweaked the shader on the hoary old Future Hair when I updated it and now it is one of the best-looking hairs for Genesis that I own. The only thing I found that was weird was that Future Hair and one or two others had to be translated upward before conversion or they would end up clipping the head in final version no matter what Clone morph I chose. Go figure. It was a very small number of hairs that had this issue, and even that was easy to get around.
I'm so excited to have all these hairs for Genesis that their original creators never in a million years would have bothered making dufs for! My People/Hair directory has tripled in size overnight and all of the morphs still work. Even the Ariel hair is on Genesis now. Squee.
Oh, and this works with cr2 hairs as well, you just substitute "convert to weightmapping" instead of "prop to figure." I now have my delicious Midnight Prince hair back as well.
What character did you clone from? I tried M4, D3, V4 and I always I get hair floating in the air.
April posted here Erdehel, there is a list on one of the pages. She continued to use M3 and V3 for many of her models so if you have those shapes (which come with templates for transferring clothing and hair) then try those templates
Glad your having such fun. I recently converted over the Fantasy Drops hair set from AlfaSeed. Turned out just wonderful. Now I do see issues with the transfer of longer hair as it ends up with "kinks" in the hair around the shoulders. I tried smoothing it out and then took it into ZBrush and that was a mess. So I gave up on that. Not sure how to fix that. If someone knows let me know and I'll add that onto the tutorial.
http://www.daz3d.com/forums/discussion/6841/P105/#178077 Starting with post #114
No, I ran into that as well. It's less a problem with hairs that are narrower in back (Sissy Lebeaux by SAV and Sonia both look okay) but it's definitely there, I just don't have as many of those because they tend to cover up the clothes I'm trying to sell. :-D
HAHAHA... of course honey! :P
Alright now I need to manually apply Runtime textures onto Genesis in Zbrush I guess... Thanks for the link!
Redacted
If it's by AprilYSH she actually used V3 and M3 for allot of her earlier hair styles even after V4 and M4 were on the market for a year. There is a list here in the thread with all her hairs listed by figure created for originally It's on page 4.
When autofit comes up, say no/cancel. It will let the hair load unconverted. Then with cr2 hair, instead of "convert prop to figure" you go directly to "convert to TriAx weight mapping." Then TU will work.
Hi,
Thanks to that brilliant hair tutorial I was able to get Guillaume Hair to work on M6, it mystified me as to to why Neftis made that an hr2 (That's a Poser format, and FiberMesh hair won't even load in Poser.) and not a conforming style, if it had been then I could have used autofit. Still, the tutorial worked and I can now use it as I intended to.
I owe you a big debt of gratitude, as I would have returned the hair (which I actually did a year ago when I previously bought it for Poser) had I not found your tutorial
CHEERS!
PS (The render took 4 1/2 hours!)
I don't have Guillaume ... but why shouldn't FiberMesh hair load in Poser???
It's Geometry (very much geometry, LOL), not curves like LAMH or Garibaldi or PoserDynamic hair.
Nikkou hair fitted to the BalljointBoy (a bit in a hurry - with more time I could do better) and rendered in PP2014
He doesn't know what you are talking about ... LOL
(Just a fun render, because I had to test your statement)
Merry Christmas!
Ok, it would appear that 'some' will load, but, when I tried to load Guillaume Hair in PP2012, it just stalled and sat for ages not doing anything, I tried everything I could, but, nothing would happen. It's possible it had a high polygon count and may have loaded eventually, but, I was too fed up by then to want to do anything more with it. Still, I'm solely a DS user now, so it doesn't really matter.
Merry Christmas to you too!
CHEERS!
Okay I know it's been awhile since this was posted ,and it took awhile for me to find it and that being said I am so grateful to RAMWolf for the tutorial on converting hair,cause I've had a bunch of hair that I haven't been able to use
with Genesis ,and the TOON shapes now I can!!! YA!! Thank you Rammie !!Thank you!!
Awwwwwww.... your very welcome.
I'd just like to say, this tutorial is just as relevant today. Literally, today. I followed your tutorial and was able to fit GQ Event Hair to Kimo 7. M4 to G3M, what a leap. Granted, it looks better in 3Delight than Iray, but the fact remains, it's doable. And it's easy. Oh, yeah... I was working in 4.9 beta. Here's a quick render:
I stumbled across a link to this tutorial from a thread started yesterday morning asking how to prevent losing morphs when fitting older hair to genesis models. Now I know how all those PAs got such great promos while still using previous generations hair! I've bookmarked this thread for future reference.
Thank you!
L'Adair aren't there hair shaders for Iray,you could use on the older hairs??
Looks grreat. Glad it's still a viable tutorial! :-)
Yes. I should give it a try. I have OOT's IrayHair Pair Shader.
However, I don't think either OOT's shaders or Slosh's UHT shaders will help where sections of hair appear to be floating over the head... I'll show you what I mean, but I'll have to render it first...
