G2F only displayed in blocks, G2M is fine.
Hello!
I'm not sure what I did to make this happen, but when I load Genesis2 Female, I get the attached result.
The figures always displays as blocks although I have selected "Texture shaded".
When I load Genesis2 Male, all is fine.
I have already un-installed and re-installed DAZ and the contents, that didn't change anything.
Re-installing Windows would surely resolve the problem, but that would be my last option.
Can anybody help?
Thank you!
  • The stuff in the My Library/Content folder should be in My Library itself - did you install manually or using DIM?
  • Hi Richard,
    I don't remember. I think I chose DCIM.
  • DIM shouldn't do that unless there's an issue with the paths - click the gear icon at top-right of the interface to open preferences, take a screen shot of the Installation tab, and post it here.
  • Sorry, which gear icon do you mean? I guess you have a different layout than I have.
    654 x 562 - 52K
  • For Install Manager, not for Daz Studio. The Installation tab for Install Manager will show where it is placing files.
  • Here it is. Thanks!
    564 x 549 - 65K
  • OK, that's Putting the content in the My Daz 3D Library folder in Public Documenmts, which is the default - however, your earlier screenshot shows Genesis 3 female in the Content folder in the My Library folder, which would be wrong. The \My Library\Content folder should not be there at all - everything in it should be in the My Library folder or, if isntalled with DIM, in the My Daz 3d Library folder.
  • Hi Richard, do you have any suggestion for me? Or should I just re-install Windows? I wanted to wait with that a few more weeks, but it ain't any problem.
  • As I said, the stuff that is curently in /My Library/Content should be in /My Library only, not in a sub-folder as at least soem of it is now - Reinstalling with DIM would work (actually it would go in My Daz 3D Library, but as long as it is in the root of a content directory not - as in the Content Library image - a sub-folder it should work.
