G2F only displayed in blocks, G2M is fine.
Hello!
I'm not sure what I did to make this happen, but when I load Genesis2 Female, I get the attached result.
The figures always displays as blocks although I have selected "Texture shaded".
When I load Genesis2 Male, all is fine.
I have already un-installed and re-installed DAZ and the contents, that didn't change anything.
Re-installing Windows would surely resolve the problem, but that would be my last option.
Can anybody help?
Thank you!
1556 x 933 - 153K
The stuff in the My Library/Content folder should be in My Library itself - did you install manually or using DIM?
Hi Richard,
I don't remember. I think I chose DCIM.
DIM shouldn't do that unless there's an issue with the paths - click the gear icon at top-right of the interface to open preferences, take a screen shot of the Installation tab, and post it here.
Sorry, which gear icon do you mean? I guess you have a different layout than I have.
For Install Manager, not for Daz Studio. The Installation tab for Install Manager will show where it is placing files.
Here it is. Thanks!
OK, that's Putting the content in the My Daz 3D Library folder in Public Documenmts, which is the default - however, your earlier screenshot shows Genesis 3 female in the Content folder in the My Library folder, which would be wrong. The \My Library\Content folder should not be there at all - everything in it should be in the My Library folder or, if isntalled with DIM, in the My Daz 3d Library folder.
Hi Richard, do you have any suggestion for me? Or should I just re-install Windows? I wanted to wait with that a few more weeks, but it ain't any problem.
As I said, the stuff that is curently in /My Library/Content should be in /My Library only, not in a sub-folder as at least soem of it is now - Reinstalling with DIM would work (actually it would go in My Daz 3D Library, but as long as it is in the root of a content directory not - as in the Content Library image - a sub-folder it should work.
