Materials problem?
rickfoxxx74331700
When rendering nails fail.
I need help. I think it's a problem with materials. But can't locate it it. Any idea?
rickfoxxx74331700
Some of them have the displacement set too high. If so, turning it down should help.
My question is...which is the problem...the black or the lack of black?
If I'm not mistaken that's one of the dark red shades of nail polish. Some of the textures also have for 'chipped nails' or really nice nails.
However some of them also had the displacement settings rather high ... depending upon how close one wanted to render the figure.
Looks like my hands two days after a show when I haven't bothered to remove my nail polish.
Now I'll just tell people the texture map isn't properly applied.
I found the problem but do not know how to solve it.
The problem is the full body morph "The Man in the Mirror". When I apply it, the nail gets distorted.
My question is:
Is it possible to apply the morph without applying it on nails?
If you're referring to this: http://www.daz3d.com/shop/the-man-in-the-mirror for M4 ... guess I should ask now, which figure are you using? It looked like something I've seen happen on Genesis.
I used Michael4 and I've installed Hiro4 too.
Okay, now I don't have that particular morph set ... places to check for more poses might be under "hands" or when you click [choose] the hand, over on the parameter tab there may be a slider/dial to make adjustments?
Sometimes there's a readme or text file with a few instructions thrown in with products that may or not be of help. [found by manually poking through the folders looking for them]
If there's no help there; the only thing I can think of quickly would be to dial the morph out when doing closeups of the hand.
Maybe somebody who has those morphs will chime in.
lol ... mine always start chipping from the bottom.
There's probably a Ven diagram of "Nail Polish that Dries Quickly", "Nail Polish that Lasts Long", and "Nail Polish that is the Exact Colour I Want" and it would be three circles non-converging circles.
Was thinking this one over, technically one could make a mini-morph to undo the handmorph ... I haven't tried making morphs for M4 in D/S4, I use D/S3 and a free script. Should be possible though.
The basic outline would be to set up the figure as you want it - shape wise, don't worry about textures - send it to Hexagon via the bridge, use the "inflate" "smooth" brushes under uvmaps "carefully" ... do not add or remove any of the dots/lines/faces ... send it back to D/S over the bridge and make the morph. If you like it, save it. Do NOT share it though. [few more steps are necessary before files can be shared]
