Iray Frozen Brothers for Genesis 3 Male [Commercial]
GKDantas
http://www.daz3d.com/iray-frozen-brothers-for-genesis-3-male
A real shader set to create a winter scene with a real ice Genesis 3 Male and 3 shaders to turn everything into iced objects and props.
You get 5 materials to create:
A Crystal Clear Ice
A Frosted Ice
A Glacial Blue Ice
Dispersion ON (*abbe)
Dispersion OFF (*abbe)
Also you get 5 SHADERS PRESETS + 9 presets to change tiling:
A Crystal Clear Ice Shader
A Frosted Ice Shader
A Glacial Blue Ice Shader
9 Presets to Change Shaders Tiling ( X1, X2, X3, X4, X5, X10, X20, X50 and X100)
This set use Iray engine to create the better visual quality for your render.
All image maps are 4096 X 4096, so your renders will look amazing even in close up.
Combined with IBLs lights and a scenario the ice will look more realistic then ever before.
Dispersion refraction increase the render time.
I already bought Iray Frozen Sisters (http://www.daz3d.com/iray-frozen-sisters-for-genesis-3-female) which also comes with the general use shaders. So, I'm wondering what, if any, real advantage there would be to buying the Iray Frozen Brothers as well?
The problem is that yusing only the shader you will get seams problems in figures like Genesis or even Vic, so I draw a handed painted texture for Genesis Femalçe and Male, so no seams problems happen. Unfortunatelly I couldnt create a bundle (packs submitted in separeted cant be a bundle).
Gorgeous
